Thread: HELP! Hissing sound after drilling though firewall
Results 1 to 19 of 19
  1. #1
    Quincy, Mass
    You could probably just tape it up really well since its just a vac line for the hvac. Unless you cut it up really bad
    No more GP 04 Impala SS Indy:
  2. #2 Re: HELP! Hissing sound after drilling though firewall
    Pennsylvania
    Quote Originally Posted by Swiggles View Post
    See, here's the problem with that: that vacuum line connects to multiple spots and will cause issues. Fix it right the first time.
  3. #3 Re: HELP! Hissing sound after drilling though firewall
    Houston
    Quote Originally Posted by SlowNA06 View Post
    Its a straight line that runs from the tree to the HVAC. It doesnt connect to anything else. But I agree, fix it right. Get at least 8ft of vac line and rerun that line.
  4. #4 Re: HELP! Hissing sound after drilling though firewall
    Pennsylvania
    Whut?
    The vacuum manifold connects to no less than the intake, brake booster, and bypass valve vacuum actuator, as well as the HVAC.
  5. #5 Re: HELP! Hissing sound after drilling though firewall
    Houston
    Whut?
    Yes, but the HVAC line runs directly from the manifold to the HVAC. You can just cap off the HVAC port on the manifold and it wont affect anything. You'll just have issues switching levels on your heater/ac.
  6. #6 Re: HELP! Hissing sound after drilling though firewall
    Howell, NJ
    I know that if I disconnect this line from the engine it will idle funny. The line cant be broken that bad because its idling fine.
  7. #7 Re: HELP! Hissing sound after drilling though firewall
    Howell, NJ
    There's a chance that i may have also clipped some of the wires. Everything is working fine. Ill check to see if i hit anything in the morning.
  1. Drilling and Tapping Phenolic Spacer
    By ls1camino in forum General Tech Discussion
    Last Post: 06-14-2011, 07:19 PM
  2. Hissing noise at the Firewall
    By darkfox1009 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2011, 04:43 PM
  3. Brakes make a hissing sound
    By supercharged98 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2010, 09:09 PM
  4. Drilling a Tstat????
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 06:49 PM
  5. Drilling holes in the trunk???
    By MysticStyl3z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2008, 10:58 AM
