Thread: 4" Rear Deck Speakers
Results 1 to 18 of 18
  1. #1 4" Rear Deck Speakers
    SE Level Member Aceoage's Avatar
    Jul 2008
    Saskatchewan, Canada
    I have purchased some type R 5 1/4 and 6x9 speakers.
    So... my question is how much would i benefit from replacing the 4" rear deck speakers as well?
  2. #2 Re: 4" Rear Deck Speakers
    Jul 2008
    sumter,south carolina
    the so called stock 6x9s put out so called bass...and the 4s put out highs...the type rs are good 3 way speakers.i left my 4s out when i replaced my 6x9s...just left a hole in back dash.if u do this and have a sub box.u will get much better bass response out of subs seeing is how the bass will have 2 more ports to escape out of.my opinion is leave the 4s out either way.i have memphis 5 1/4s and memphis 6 x 9s...and get all the high and mid i need outta them.
  3. #3 Re: 4" Rear Deck Speakers
    GT Level Member 04 GTP COMP G's Avatar
    Jul 2008
    hey Ace. It's great to see another Gapper here.
  4. #4 Re: 4" Rear Deck Speakers
    Jul 2008
    Thanks gtpinsc, I installed my setup as you recommended.I was impressed by the difference these new speakers made. The only real problem i had was rewiring the front speakers.
  5. #5 Re: 4" Rear Deck Speakers
    Jul 2008
    Quote Originally Posted by Aceoage View Post
    no problem man...im confused as to why u had wiring probs for front speakers...those were the easiest for me...they have the little connectors that just slide over the posi and ground contacts.did u run a amp to them?if so i see where ur comin from.
  6. #6 Re: 4" Rear Deck Speakers
    Jul 2008
    Yes i did, it was really a learning experience for me in wiring. Not I'm just worried about how the car will cope with the extra load.
  7. #7 Re: 4" Rear Deck Speakers
    Aug 2008
    Whitby Ontario
    Buy a cap, i have a 2400 watt system in my 'pala,. The w bodys make alot of power, but have a slow drain i find. With a capacitor, my light don't flicker and it evens out the load on the car..
  8. #8 Re: 4" Rear Deck Speakers
    Jul 2008
    what all u got in ur car as far as audio?
  9. #9 Re: 4" Rear Deck Speakers
    Jul 2008
    Stock deck, Pioneer Amp (4 channel) and the Alpine Speakers i previously mentioned.
  10. #10 Re: 4" Rear Deck Speakers
    Jul 2008
    oooooo u would get sooooooooo much better sound out of a new deck.i always reccomend pioneer premier...its not the cheapest but very user friendly.i paid close to 400 for my premier like 3 years ago never had any problems out of it.
  11. #11 Re: 4" Rear Deck Speakers
    Since you already have subs, wouldn't it be better just to put 6.5's in place for the 6x9. There more well balanced and will get louder and stay louder and last longer.
  12. #12 Re: 4" Rear Deck Speakers
    Jul 2008
    Probably but, it's too late for that now unfortunately.
    I may get a new deck if i did I would probably get an Alpine iDA-X200 for my ipod.
  13. #13 Re: 4" Rear Deck Speakers
    Jul 2008
    What will happen if i reconnect my factory tweeters? It said on the box 2 tweeters in parallel can cause a fault.
  14. #14 Re: 4" Rear Deck Speakers
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    mmmmm premier FTW!!!! i have had one in my car for 3 years and not one problem!
  15. #15 Re: 4" Rear Deck Speakers
    GT Level Member GOINDEF's Avatar
    Holly, MI
    yeah caps are great too for holding off on buying an upgraded alternator, I've got a 5 farad cap in my car with my system and HID'S and 3 amps, and I havent had problems yet with dimming while running the stock ALT
  1. Rear speakers cut out??
    By 91z in forum Audio, Security & Visual Electronics
    Last Post: 09-16-2008, 09:53 PM
  2. New deck, old deck, or adaptors, HU relocation?
    By yourTVlies in forum Audio, Security & Visual Electronics
    Last Post: 07-21-2008, 01:20 PM
  3. how to remove rear speakers ??
    By bayareagtp in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2008, 10:52 AM
  4. 4" speakers in the rear deck....
    By halfwit in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2008, 05:40 AM
  5. no rear speakers
    By 59chevy in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2008, 06:44 PM
