You attach the heavy gauge wires to the correct smaller gauge wires if the ignition switch. The 12 volt power must be run to the back of the fuse box where there is a higher amp wire or run directly to the battery.
Thank you very much i was curious because in previous cars all the wires werent so small thanks again
