Thread: which wire is low beam
Results 1 to 10 of 10
blakgtp which wire is low beam 11-30-2011, 04:33 PM
blakgtp Re: which wire is low beam 11-30-2011, 04:33 PM
dpzelenak Re: which wire is low beam 11-30-2011, 06:05 PM
stealthee Re: which wire is low beam 11-30-2011, 06:23 PM
Scottydoggs Re: which wire is low beam 11-30-2011, 06:59 PM
stealthee Re: which wire is low beam 11-30-2011, 07:02 PM
blakgtp Re: which wire is low beam 12-01-2011, 12:45 AM
BillBoost37 Re: which wire is low beam 12-01-2011, 06:48 AM
  1. #1 which wire is low beam
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    hi, so ive searched and for some reason cant find out which wire of the 3 headlight wires is the lowbeam one?
  2. #2 Re: which wire is low beam
    Sep 2011
    Vancouver
    1997 gp
  3. #3 Re: which wire is low beam
    iirc the green is high beam so the other one
    SMGPFC Member #10
  4. #4 Re: which wire is low beam
    SWPA
    Why not use a test light instead of guess?
  5. #5 Re: which wire is low beam
    the cheep tester is like 2 or 3 bucks just stick the probe end into the socket when the low beams are on. keep testing the slots till it lights up.
  6. #6 Re: which wire is low beam
    SWPA
    Test light and a digital multi meter are two tools I don't use all the time, but I could not live without. They've helped cure many issues, and they took a whopping $20 total out of my pocket.
  7. #7 Re: which wire is low beam
    i love when i get the call from friends that their trailer wires got pulled out of the plug, and they cant make the trailer lights work, i show up with a 3 dollar test light and make it work.
  8. #8 Re: which wire is low beam
    Sep 2011
    Vancouver
    ok got them wired. and ya i didnt have any multi meter or test light stuff here. thanks for quick replies.
  9. #9 Re: which wire is low beam
    An on the spot test light is a side marker bulb. It's got leads you can straighten ...use to test,...fold back over and put back into the light socket.
    Just sayin... Me and MacGyver are good buddies.
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. Hi and Low beam together mod?
    By codysGS in forum Buick Regal
    Last Post: 02-09-2011, 01:26 PM
  3. Need High Beam, Low Beam, Fog wiring help...
    By TuKoolGTP in forum General Tech Discussion
    Last Post: 12-29-2009, 12:57 PM
  4. HID's: Lo/Hi beam reversed
    By Bedwards in forum Visual/Body Modifications
    Last Post: 11-03-2009, 01:49 PM
  5. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
