Thread: Need Help Installing Subs in 05 Grand Prix
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #1 Re: Need Help Installing Subs in 05 Grand Prix
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    do you have pictures of this?
  2. #2 Re: Need Help Installing Subs in 05 Grand Prix
    Nov 2011
    Decatur
    where do you find one of these 20-30 dollar harnesses? on crutchfield theyre $100 but 50% off if you buy a headunit
  3. #3 Re: Need Help Installing Subs in 05 Grand Prix
    SE Level Member jaked1985's Avatar
    Jan 2012
    West Union, Iowa, United States
    Quote Originally Posted by 2dee11 View Post
    Crutchfield is expensive
    Look here
    Wiring Harnesses (Harness Type: Standard) | Car Stereo Installation & Accessories | Car Audio/Video Installation & Accessories | Car Audio, Video & GPS at Sonic Electronix
  4. #4 Re: Need Help Installing Subs in 05 Grand Prix
    Nov 2011
    Decatur
    dannng! thats like dirt cheap!
    does it provide a 12v power source?
  5. #5 Re: Need Help Installing Subs in 05 Grand Prix
    Nov 2011
    Decatur
    Quote Originally Posted by SlowNA06 View Post
    I think most people run the power wire through the rubber grommet in the footwell of the front passenger seat. Just pop off the plastics and run it along the other wires there. No need to cut up your carpet.
    is this what you are talking about?
    Quote Originally Posted by 06grandprix93 View Post
    Or instead of wiring through the firewall, you could do what I did. On the passenger side, there is a hole by the door jam that runs all the way up the inside of the fender and then there is another hole right next to the battery. The wire is slightly visible though where the door closes, but its not noticeable unless you are looking for it. Only thing is, this might not work if you're using 0 gauge or something cause the door might not be able to shut
    i saw what you were talking about today and that looks pretty great. if i cant figure out this firewall thing that is deffinetly and option i will look into
  6. #6 Re: Need Help Installing Subs in 05 Grand Prix
    Pennsylvania
    You got it dude. Just pop the rubber piece out and make the hole a little bigger to squeeze stuff in. Optionally, you can squeeze a little RTV or caulk over the hole when you're done running wires. I didn't bother and don't get any water or dirt or anything through.
  7. #7 Re: Need Help Installing Subs in 05 Grand Prix
    Stockbridge
    hey guys, i just got a 2005 grand prix today (excited! its my first car, a hand-me-down from my mom) but i was also given a set of two 12" subs from a friend of mine a year or so ago. and im looking to install them in my Grand Prix. it does NOT have the monsoon system or the sterring controls. i was originally going to install and after-market head unit as well but found that the adapter was about $100 extra. so i want to just hook them up (with an amp) to the stock head unit. to do this i know you need to use a Line Output Converter. i also know you need to tap into the rear speaker wires. im not sure on how to do this though. you dont lose your rear spearkers do you? any pictures or videos would be excellent help! also where is a good place to put the power wire through the firewall? thanks in advance for all the help! stupid adapter through everything off. i knew how to set em up with an external head unit
    Hey you can hardwire the radio in with the amp. its a little difficult but i did it in my grand prix. the only downfall you will not have door chimes. if you need the color set up i can send it to you.
  8. #8 Re: Need Help Installing Subs in 05 Grand Prix
    GT Level Member des19's Avatar
    May 2011
    Ontario
    using a line out convertor will sound horrible. invest in a new deck.
  9. #9 Re: Need Help Installing Subs in 05 Grand Prix
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    Look up "The big 3"
    some ideas on my youtube
    your alt will look different...
  1. Installing OEM foglight on 2004+ Grand Prix
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 10-18-2022, 03:22 PM
  3. Installing sub in 99 grand prix gt
    By protoplayer in forum Audio, Security & Visual Electronics
    Last Post: 08-01-2011, 07:11 PM
  4. Installing subs
    By bilak09 in forum Audio, Security & Visual Electronics
    Last Post: 06-26-2010, 10:33 PM
  5. 2007 grand prix installing after market CD player
    By slimhero in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2009, 10:57 PM
