Thread: Need Help Installing Subs in 05 Grand Prix
Results 1 to 20 of 29
  1. #1 Re: Need Help Installing Subs in 05 Grand Prix
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    Quote Originally Posted by SlowNA06 View Post
    I think most people run the power wire through the rubber grommet in the footwell of the front passenger seat. Just pop off the plastics and run it along the other wires there. No need to cut up your carpet.
    is this what you are talking about?
    Quote Originally Posted by 06grandprix93 View Post
    Or instead of wiring through the firewall, you could do what I did. On the passenger side, there is a hole by the door jam that runs all the way up the inside of the fender and then there is another hole right next to the battery. The wire is slightly visible though where the door closes, but its not noticeable unless you are looking for it. Only thing is, this might not work if you're using 0 gauge or something cause the door might not be able to shut
    i saw what you were talking about today and that looks pretty great. if i cant figure out this firewall thing that is deffinetly and option i will look into
  2. #2 Re: Need Help Installing Subs in 05 Grand Prix
    Pennsylvania
    Quote Originally Posted by 2dee11 View Post
    You got it dude. Just pop the rubber piece out and make the hole a little bigger to squeeze stuff in. Optionally, you can squeeze a little RTV or caulk over the hole when you're done running wires. I didn't bother and don't get any water or dirt or anything through.
  1. Installing OEM foglight on 2004+ Grand Prix
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 10-18-2022, 03:22 PM
  3. Installing sub in 99 grand prix gt
    By protoplayer in forum Audio, Security & Visual Electronics
    Last Post: 08-01-2011, 07:11 PM
  4. Installing subs
    By bilak09 in forum Audio, Security & Visual Electronics
    Last Post: 06-26-2010, 10:33 PM
  5. 2007 grand prix installing after market CD player
    By slimhero in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2009, 10:57 PM
