Thread: Nothing on interior works
Results 1 to 6 of 6
  1. #1 Re: Nothing on interior works
    SE Level Member 1986c10's Avatar
    Nov 2011
    Kalamazoo Michigan
    Thanks fordman for the response. All of your points seem pretty spot on so im gonna start tearing the thing apart and see what happens. Regarding the manual lock, it seems to not wanna move either direction on both the driver and passenger side, almost as if as i press the manual lock, someone is pressing the lock switch to fight against it if that makes sense...
    1997 grand prix gt coupe dual flowmasters
    1982 chevy c10 full roller forged 355, 12 bolt rear
    1986 chevy c10 lwb no engine
  2. #2 Re: Nothing on interior works
    St. Louis
    Yea, that sounds like the rod that conencts from the manual lock to the lock inside the door is locked/bent up. Hopefully an easy fix once the panel is out of the way. You should be able to see most of it with the panel off, but some of it you may have to just feel for.
  1. How Axe really works....
    Last Post: 07-30-2011, 11:32 PM
  2. Horn Only Works Sometimes
    By CSteen85 in forum Audio, Security & Visual Electronics
    Last Post: 04-06-2010, 09:00 PM
  3. 99 GTP A/C works great, then stops, then works great again
    By stotzbotz in forum General Tech Discussion
    Last Post: 09-27-2009, 02:39 PM
  4. It Works!!!
    By 02BlueGT in forum PCM Tuning
    Last Post: 08-31-2008, 01:02 AM
  5. Finally! ABS Works again
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 07-10-2008, 12:59 PM
