Thread: The dimmer switch, it does nothing!
Results 1 to 6 of 6
  1. #1 Re: The dimmer switch, it does nothing!
    SE Level Member Lionel's Avatar
    Moncton N.B.
    I have an 04, does your switch turn on your interior lights when you turn on the switch all the way? if it doesn't im thinking a bad switch
  2. #2 Re: The dimmer switch, it does nothing!
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Lionel View Post
    Nope, as far as I can tell, it does absolutely nothing. I'm guessing I'm gonna need to remove a good amount of the dash to get to it though, doh.
  3. #3 Re: The dimmer switch, it does nothing!
    Oct 2011
    Toledo, OH
    Well, you only have to remove 3 screws and 3 pieces of dash to get to the dimmer switch. It takes 5 minutes. And when you find out that the switch just WASN'T PLUGGED IN, you can put it all back together in half the time and go and work on your other ****.
    7"
  1. Replacing a dimmer switch on 2008 grand prix
    By cadbob in forum General Tech Discussion
    Last Post: 10-15-2011, 12:19 PM
  2. gauge cluster dimmer problem
    By coreygnar in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2011, 01:13 PM
  3. Interior light dimmer control
    By grandprixgtpsc00 in forum General Tech Discussion
    Last Post: 01-23-2011, 03:44 PM
  4. Dimmer Switch
    By jack08 in forum Visual/Body Modifications
    Last Post: 03-05-2009, 06:29 PM
