Thread: The dimmer switch, it does nothing!
Results 1 to 6 of 6
  1. #1 The dimmer switch, it does nothing!
    Oct 2011
    Toledo, OH
    Yup, it doesn't do anything. Have all the dash lights at night. Doesn't dim them at all, and when the headlights are off I can't use the dimmer to turn the gauge lights on.
    Any thoughts? Just a bad switch? 05 GTP
  2. #2 Re: The dimmer switch, it does nothing!
    SE Level Member Lionel's Avatar
    Moncton N.B.
    I have an 04, does your switch turn on your interior lights when you turn on the switch all the way? if it doesn't im thinking a bad switch
  3. #3 Re: The dimmer switch, it does nothing!
    GT Level Member gunsn88's Avatar
    May 2011
    Vineland, New Jersey, United States
    sounds bad. id get a used one on ebay
    Imagination is more important then knowledge.
  4. #4 Re: The dimmer switch, it does nothing!
    Yoga city
    I would take it apart by peeling back corners to reveal four Phillips screws. Now it will slide apart and you should be able to see the dimmer wheel. Check the connections between the wheel and metal contacts that touch the board. I have had to much grease on mine and this helped
  5. #5 Re: The dimmer switch, it does nothing!
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Lionel View Post
    Nope, as far as I can tell, it does absolutely nothing. I'm guessing I'm gonna need to remove a good amount of the dash to get to it though, doh.
  6. #6 Re: The dimmer switch, it does nothing!
    Oct 2011
    Toledo, OH
    Well, you only have to remove 3 screws and 3 pieces of dash to get to the dimmer switch. It takes 5 minutes. And when you find out that the switch just WASN'T PLUGGED IN, you can put it all back together in half the time and go and work on your other ****.
    7"
  1. Replacing a dimmer switch on 2008 grand prix
    By cadbob in forum General Tech Discussion
    Last Post: 10-15-2011, 12:19 PM
  2. gauge cluster dimmer problem
    By coreygnar in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2011, 01:13 PM
  3. Interior light dimmer control
    By grandprixgtpsc00 in forum General Tech Discussion
    Last Post: 01-23-2011, 03:44 PM
  4. Dimmer Switch
    By jack08 in forum Visual/Body Modifications
    Last Post: 03-05-2009, 06:29 PM
