Thread: Pre amp output questions
Results 1 to 4 of 4
  1. #1 Pre amp output questions
    May 2011
    Mi
    I currently have a kenwood reciever that has 3 pre amp outs, front, rear, and sub. im using the front and rear outs and the new double din reciever i want has a front pre out and a switchable rear/sub preamp out. so my question is how can i run my rear speakers and subs on amps at the same time. would it work to just use the front pre amp for my rear speakers to i can have full subwoofer control at the unit? if my thinking is correct it would just stop me from having front/rear fade option.
  2. #2 Re: Pre amp output questions
    SE Level Member Johnyv0591's Avatar
    Your thinking is correct. You would need a pair of Y-adapters to split that front RCA pre-outs. you would lose fade from from to back but retain all sub control at the head.
  3. #3 Re: Pre amp output questions
    May 2011
    Mi
    alright thanks, just wanted to make sure
  4. #4 Re: Pre amp output questions
    May 2011
    Mi
    If i plug rca's in the front preamp out will the front speaker out stop making signal or can both be hooked up and play at the same time
  1. high output alt
    By tesh123 in forum Audio, Security & Visual Electronics
    Last Post: 03-18-2011, 10:37 AM
  2. Output shaft questions?
    By johnsmith in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2010, 07:58 PM
  3. Alternator output
    By Dohner in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2009, 11:25 PM
  4. Where is the OBD output?
    By HOPPY in forum General Tech Discussion
    Last Post: 07-08-2008, 10:10 AM
