Thread: Amp mounting setup.
Results 1 to 15 of 15
  1. #1 Amp mounting setup.
    SE Level Member BeastGT's Avatar
    Aug 2011
    Palm Coast
    Anyone have any creative place to mount my amp. I was thinking in the rear passthrough. i have a 2000 gt.
  2. #2 Re: Amp mounting setup.
    North Jersey
    personally, i'm trying to figure a way to mount it behind the right tail in the fender under the carpet, can't quite manage a way to make it work yet.
  3. #3 Re: Amp mounting setup.
    GTP Level Member joshv's Avatar
    canada
    under the spare tire
  4. #4 Re: Amp mounting setup.
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by jerZcavy4120 View Post
    Why would you want to do that?
    Difficult to access if you even need to again, and that's like a heat trap too.
  5. #5 Re: Amp mounting setup.
    swift current,sask.
    Under the rear deck? just low enough so you can access all of the amp's controls but just enough out of the way.
  6. #6 Re: Amp mounting setup.
    I live here. TLSheff's Avatar
    Quote Originally Posted by whiney View Post
    ^ this
    Seen it done this way so it was out of the way because the person used the trunk as a trunk but still wanted good sound from the speakers.
    Any place that is constricting heat is asking for the amp to burn up, stay in "protective" mode 24/7, or cause a fire. Under the carpet is a bad place, they need lots of air to breathe... spare tire area wouldn't be too bad but again... would heat up the area and unless you install fans in the board your going to have problems.
    Most places create a custom box and attach to it, or make a mounting kit somewhere in the trunk designed for the amp itself... for instance, sub on one side, amp on the other, wires under the mat so its clean.
  7. #7 Re: Amp mounting setup.
    Nov 2008
    Waterloo, Iowa
    Mine is pretty much in the most open spot in the trunk and has on occasion gone into protect mode, and it's a pretty decent amp. I've thought bought fans for it even, so yeah, air air air, electronic stuff loves it.
  8. #8 Re: Amp mounting setup.
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    I had mine on the deck lid before, liked it! Now I have a way bigger amp and my trunk lid flexes way tooo much!
    https://fbcdn-sphotos-a.akamaihd.net..._5092044_n.jpg
    way old pic!!! Now my amp is in front of my box, stays cool, easy to adjust while I can listen to it! New setup on my youtube (1 SMD 15'' on a SAZ3500D, it's still @ 2 ohms, 1800 watts, waiting to get the brackets to fit a large case 300a Iraggi alt., then it's 1 ohm 3600 watts!!!)
  9. #9 Re: Amp mounting setup.
    North Jersey
    i actually probably should just mount it on the decklid...hmmm possibilites.
  10. #10 Re: Amp mounting setup.
    canada
    I sugested under spare tire lol i dunno? But i just have my subs facing the rear seats and my amp is screwed to the back of the box lots of air and its got built in cooling system
  11. #11 Re: Amp mounting setup.
    My new setup is my amp in front of the 15'' SMD, inside the cabin, way cool breezes!
    ovnorfolkva's Channel - YouTube
  12. #12 Re: Amp mounting setup.
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by chrishova View Post
    Your sub is facing the wrong way. Lulz. :P
  13. #13 Re: Amp mounting setup.
    It is facing forward, towards the people, it's right. I don't need to face it into the trunk because I already made the box tuned to 29htz, LOW LOW!!!
  14. #14 Re: Amp mounting setup.
    29 is high though.
  15. #15 Re: Amp mounting setup.
    Bunnell, FL
    under the front seats
    I'm a Sex Offender
  1. Mounting Fogs
    By csssaint12 in forum Visual/Body Modifications
    Last Post: 07-27-2011, 09:30 AM
  2. PCM mounting
    By grannyprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 03:50 AM
  3. Mounting Kit??????
    By kingbrentdwyer in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2008, 02:08 AM
  4. ZZP FMHE mounting
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2008, 07:56 PM
  5. GPS Mounting
    By iflycessnas05 in forum General Tech Discussion
    Last Post: 06-26-2008, 08:36 PM
