Thread: best battery for under the hood?
Results 1 to 20 of 98
  1. #1 Re: best battery for under the hood?
    Sep 2011
    Arkansas
    lmao... yes I have. Are you suggesting that our alternators supply 120 amps continuously, even at idle? No, they do not. When the draw that serious... aka, a need for a quick discharge to satisfy a power-hungry amplifier, occurs if he is at idle, where oh where will that extra amperage come from? Also, yes, voltage does drop below 11v without a sufficient electrical system... if it never happened, and was impossible, as you imply, then there would be no need for the protection circuit concerning low voltage. If you've never heard of a system capable of causing a voltage drop to below 11v, I question how many large systems you have personally been involved with.I addressed the issue at hand perfectly: a stock battery and a 120amp alternator is not sufficient to run 2600 watts on a daily basis. If the OP does this, you can be the first to offer up every explanation in the world to why his equipment should not have failed when something goes wrong.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  2. #2 Re: best battery for under the hood?
    Feb 2009
    Virginia
    Quote Originally Posted by Fatboy501 View Post
    Not at all!! I was wondering when this would come up :>
    But with that said, ever clamped to see the AVERAGE pull of an amplifer? An alternator can't keep up with a quick discharge? Now we're talking about the voltage regulator. A well built power supply on the amplifier should have the necessary capacitance built in. A battery is in no way comparable to a capacitor.
    As far as 11V goes...I've been talking about the engine running this whole time. Not the engine off. That's why 11V isn't a valid issue at this point in time.
    11 is louder than 10!
  1. Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    By Quicksilver_GP in forum How To Write-Ups/Tech Tips
    Last Post: 08-28-2013, 09:12 PM
  2. Hood Liner or no hood Linar?
    By Taz Magister in forum General Tech Discussion
    Last Post: 02-21-2011, 11:06 AM
  3. Battery
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2009, 11:21 AM
