Thread: Lost my tunes!
Results 1 to 15 of 15
  1. #1 Lost my tunes!
    Mn
    My car is an 04 gtp with the moonsoon system. I lost the rear speakers the other day and now none of it works at all. It wont even delay lock the doors anymore. The fuse is good so im not sure what is going on.
  2. #2 Re: Lost my tunes!
    St. Cloud, MN
    Check the wiring?
  3. #3 Re: Lost my tunes!
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    thats pretty weird sounds like a wiring issue of some kind. you could check to see if its a comp problem first tho and un hook your battery for the night. see if it still does it in the morn
    silver 2003 Grand Prix GT List is on it's way to be updated
  4. #4 Re: Lost my tunes!
    Mn
    I may have it figured out. I know that these newer cars are running on a higher voltage. But i think that the alternator is bad. It was showing 15 volts last night with the lights on. Seems very high to me. Also throwing a u1301 code too. But if not I will try the battery thing.
  5. #5 Re: Lost my tunes!
    St. Cloud, MN
    Yeah that seems a little high. But if your getting that code I would still check the wires to the speakers, since everything else still seems to work correctly.
  6. #6 Re: Lost my tunes!
    In talking with I800, 15 wasn't that uncommon when cold.
  7. #7 Re: Lost my tunes!
    Mn
    I did a load test on the alt and it was good but the battery is junk. so Its just charging hi to keep up. The speaker wires are good I have checked them. The radio will still back light but wont work. I check all the bcm's with a scanner and there were no codes? Guess its time to pull the radio and start probing wires. If I could get that and a tune done so it wont lean out id be happy again. Im almost ready just to paint it lemon yellow though. Never had this much trouble with a car ever!
  8. #8 Re: Lost my tunes!
    St. Cloud, MN
    Well if you find out that your radio is shot, let me know because I have a factory radio for an 04+ for sale
    But I would pull the radio out and make sure everything is connected correctly, If it is, start testing each different colored wire...
  9. #9 Re: Lost my tunes!
    Mn
    Will do Dread. Thanks Im hoping to get to the shop this week since I cant work outside due to a ramdom ten inch snow fall. I dont care for that stuff any more. I like dry roads and curves! lol
  10. #10 Re: Lost my tunes!
    St. Cloud, MN
    LOL I hear ya. I live in MN too so I'm in the same boat as you. But keep us posted on what happens and if you need anything else.
  11. #11 Re: Lost my tunes!
    Mn
    Ok Finally got to play around with it a bit. The fuse is good. I pulled the radio and I have no 12v power on the orange wire at all. I made a jumper and it powers up and works, but the rear speakers still dont. Going to take it to the shop tomorrow and take it all apart and trace the wires. O the fun of a GM car with issues. Makes me want a mustang almost!
  12. #12 Re: Lost my tunes!
    Mn
    Im thinking that the bcm is junk? It has power comming out of it but not to the radio. Does anyone have a wiring diagram for this stuff?
  13. #13 Re: Lost my tunes!
    Mercer, Pa
    91z
    Did you ever figure out what was causing your u1301 DTC? It doesn't appear to be very common. My Bonneville set the code this morning. Don't have any other problems that I no off. Car has 180,000 plus miles.
  14. #14 Re: Lost my tunes!
    Pennsylvania
    Quote Originally Posted by sseilmnop View Post
    Isn't that code "short to battery?"
  1. car lost 4th
    By Joe m in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2010, 10:08 PM
  2. I lost :(
    By nawarkk in forum Track Sessions and Kills
    Last Post: 11-06-2009, 04:00 PM
  3. need to find someone who custom tunes(hopefully dyno) in the midwest
    By Liquifire in forum General Tech Discussion
    Last Post: 07-14-2009, 07:21 PM
  4. HELP lost 1st and 4th
    By davidl25 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-26-2009, 05:42 AM
  5. I'm new! And lost!!
    By lindzabu in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2008, 07:32 PM
