Check the wiring?
thats pretty weird sounds like a wiring issue of some kind. you could check to see if its a comp problem first tho and un hook your battery for the night. see if it still does it in the morn
I may have it figured out. I know that these newer cars are running on a higher voltage. But i think that the alternator is bad. It was showing 15 volts last night with the lights on. Seems very high to me. Also throwing a u1301 code too. But if not I will try the battery thing.
