HART Professional Subs. Best on the market, hands down! I have 2 10" HARTs. They use square copper wire for the voice coils = more efficient. Also I think they are the most expensive on the market. GL
My sub fails. It's a CVR10 4ohm DVC sub. It is wired in parallel like above though.
Sundown SD-2 10/12 "500-Watt" Subwoofer Pre-Order - Car Audio Classifieds
theres a break for you plenty of sub made for a shallow mount and at a pre-order price
ok so 10'' bazooka sub is 300$ canadian installed! no amp needed cuz it has a built in amplifier. so all you need is an aftermarket head unit! sounds good too better than a friend of mines 12'' mtx sub.
A bazooka tube? It may do what he needs... but, honestly, a bazooka tube sounds like a well-executed front stage to me. Seems to lack in the bottom end. Go with an Obsidian 12" sub.... Obsidian Car Audio . It was 160 shipped to my door. For a cheap sub, the thing is beast. It's a joint venture between Jacob of Sundown Audio and Nick of Stereo Integrity. The AQ amp is nice, but I went with an Audiopipe APSM-1300.... about 800 rms of clean power for 110 from Amazon. I'm sure you can figure out your box and wiring after that point.
I haven't read this thread through yet but I'd like to address this issue now. YOU DO NOT NEED A CAPACITOR!!! EVER!!! A properly designed circuit already has the capacitance built in. Therefore, a good amplifier does not need an external capacitor...EVER!!!
How many capacitors do you see in home audio?...anywhere else in the electronics world?
they use them for looks anything that looks cool really just a waste of money, if a sq guy runs it ether he has a cheap ass amp or wants it to look cool
In circuit design you can utilize capacitors to keep ripple down...blah blah blah. Again, if your power supply is designed and fabricated correctly within your amplifier then it's not needed.
Let me give you an idea on how big 1 farad actually is...
Granted, it's only 5.5V, but imagine putting 5 of them in series and placing them in parallel with another set of 5. That would mean they kick in somewhere around 13.75V and you'd have 10Farads....too bad they're useless.
You can buy them here if interested...$3.75 a piece!
http://www.allspectrum.com/store/1-f...old-p-261.html
The reason "SQ" guys first utilized them in the 80's was because the voltage regulator (back then was independent of the alternator) had a hard time responding quickly enough to voltage dips associated with an amplifier's irregular pull. Therefore, they added capacitance to the light circuit in a vehicle because they did not want to lose valuable points in their competition. It had absolutely NOTHING to do with the sound quality. In SQ you get points for your environment/setting. It's gay. Show me an "SQ" car and I'll show you that it has nothing to do with the sound. Sound quality is the last thing they test and it's VERY brief. Typically, the assumption is that if it's an SQ car then it probably sounds damn good. So they look real quick to see if you have the basics and there isn't much past that. Believe it or not...SQ is very trendy and cliqu'ish.
The biggest reason they don't focus on "sound quality" so much is because every listener has their own predisposition. Nobody is proportionately the same. Different ears, head shapes, body shapes, etc. All of those things effect how YOU hear the sound. Good vs. bad is VERY subjective.
True... thanks for the info. I've never messed with capacitors personally... all of my sq info is from DIYMA lol... I don't have the patience for that. I'm strictly a groundpounder.
I have heard that people that add capasitors really do clean up the "headlight dim" issues when you get the system going loud? Is that more of a placebo effect or what?
No...it's probably true. Because they have crappy amps and/or poor grounds. Most audio installs don't have solid grounds. Capacitors will help a system that doesn't have enough flow through the ground point.
Indeed... the big 3 will also go a long way to reducing/preventing headlight dimming.
