Thread: Parallel wiring / whats wrong with 6x9's
Results 1 to 3 of 3
ajoliver2010 Parallel wiring / whats wrong... 08-18-2011, 08:53 PM
KeithGTP03 Re: Parallel wiring / whats... 08-18-2011, 08:56 PM
ajoliver2010 Re: Parallel wiring / whats... 08-20-2011, 01:53 PM
  1. #1 Parallel wiring / whats wrong with 6x9's
    Jersey
    Hey gp heads. I have an eclipse xa4200 4 channel amp (100w rms per channel), alpine type s 5 1/4 coaxials in the front, some cheap pioneer 6x9 in the back. My amp says that it can go up to 200w rms x 4 in 2 ohms. I was wondering how can i accomplish that. Im not dumb when it comes to car audio but the wiring gets me confused some times smh. Also, whats wrong with having 6x9s in your car? Should i get coaxials in the back as well? Im thinking if i do that, i will have to remove the stock covering in the back...which i dont wanna do. Anyways, much help is needed...thanks
  2. #2 Re: Parallel wiring / whats wrong with 6x9's
    Houston
    6x9s are typically coaxial too. If it has a tweeter separate from the cone, then its a component speaker. If your 6x9s are 4ohm then just connect both +'s and -'s to the + and - on the same channel of the amp (or bridge them). Tada running 2ohms
  3. #3 Re: Parallel wiring / whats wrong with 6x9's
    Jersey
    Ok cool. Can i do the same to the front speakers as well? There 4 ohms as well...
  1. someone please tell me whats wrong
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2011, 03:39 PM
  2. whats wrong with my car now?!
    By mezzoni in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2010, 12:41 AM
  3. Whats wrong with my car?
    By basshead42 in forum General Tech Discussion
    Last Post: 07-01-2009, 04:25 PM
  4. Trying to figure out whats wrong with my car
    Last Post: 05-08-2009, 01:13 PM
  5. whats wrong with the se?
    By blazedgp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2008, 09:20 AM
