Thread: no brake lights...sometimes
Results 1 to 5 of 5
  1. #1 no brake lights...sometimes
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Ok, so heres what i got...My brake lights work sometimes and sometimes they dont.Everything else always works tho.Turn signals,third brake light,running lights ect. It has done it for over two years.Fuses,wires and all other simple things are good.The odd thing is that my 3rd brake light always works, so i know its not the switch.Its a 2000 with the DRL's unhooked if that makes any difference.Has anyone had this happen to them?Any feedback would be great, ive managed to not get a ticket so far but its all just luck
    Tanx
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  2. #2 Re: no brake lights...sometimes
    Akron Ohio
    Sounds like its time to trace some wires.... Have fun!
  3. #3 Re: no brake lights...sometimes
    GTP Level Member simbah's Avatar
    Lala land
    I know on the first gens when this problem occurred the only solution was to replace the turn signal switch,not sure about 2nd gens though
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  4. #4 Re: no brake lights...sometimes
    The Boss Iceman6669's Avatar
    Jun 2011
    I have had a similar problem. It has only done it once but ALL of my brake lights quit working. I checked the fuse and it was good. I rapped on the fuse block a few times and they came back on. I think my fuse block has a short in it. They people i bought it from told me about it.
  5. #5 Re: no brake lights...sometimes
    redneck tennessee
    I will check the fuse box connections then, i never thought about that. But if it is the turn signal switch, is it a b!#ch to replace?The steering column is one of the only things ive yet to take apart...
  1. brake lights not working
    By valente in forum Oldsmobile Cutlass
    Last Post: 05-26-2011, 06:51 AM
  2. ABS, Brake, P, and ! lights all on
    By nofronts in forum Brakes/Suspension/Chassis
    Last Post: 10-30-2010, 12:14 AM
  3. Brake Lights
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 05-09-2010, 09:10 PM
  4. Any Suggestions on brake lights
    By Hamm61 in forum General Tech Discussion
    Last Post: 09-29-2008, 06:50 AM
