Thread: New HU, no sound while running.
Results 1 to 10 of 10
  1. #1 New HU, no sound while running.
    Illinois
    I just purchased a Kenwood Excelon KDC-X695, GMOS-04, and a SWI-JACK.
    Took off the neg batter terminal, took out the old HU, installed everything, turned car on in accessory mode, programed SWI, everything seemed ok, even tested the onstar/door chimes. Then I turned the car on and...no sound, the HU is still lit up, says it's playing the cd/playing radio etc. but no sound, door chimes still work, onstar still works. but no sound from the radio.
    I have a 06 Grand Prix GXP with the ****soon, er monsoon, stock.
    I don't know if it's related but I unhooked the HU before I came in for the night, didn't want to leave it all exposed outside, and my interior lights wouldn't shut off, had to unhook the battery.
    Everything was working perfectly before I started.
    Any help would be hugely appreciated!
    I'll take pictures of the wiring tomorrow if it will help!
    -Mightbeinovermyhead
  2. #2 Re: New HU, no sound while running.
    GTP Level Member simbah's Avatar
    Lala land
    There are two adjustments on your GMOS-4, if you play with them you might get some sound, I did the same thing in my 06 GP GT w/ Monsoon and ended up replacing everything HU amp and speakers, as the Monsoon amp is a 8 channel amp with it sending lows to woofersonly and highs to tweeters I believe the only full bandwidth channel is for the center dash speaker, as far as the lights go I haven't a clue. Would have to look at your wiring to see.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: New HU, no sound while running.
    Illinois
    I have adjusted the sound on the GMOS, good idea though, while playing with it this morning I was able to get sound for about .5 seconds after the car is running then it just stops. still able to listen with the car in accessory mode.
  4. #4 Re: New HU, no sound while running.
    Lala land
    Lets verify your connections
    Gmos-4, 14 pin connector --radio
    blue/white --amp turn on
    red radio-- ignition
    RCA-- RCA
    these wires I did not hook up
    brown --mute wire
    green --parking brake(may not have if not video HU)
    blu/pink --speed sense wire
    green/purple-- reverse wire
    swi-jack wires
    black --ground
    red ignition --12v
    green --a7 on car connector
    then you will need to run 12v to A6 on car connector, if you want steering wheel controls to work
    wire to Hu with blue/yellow wire
    GMOS-4 24 pin connector
    yellow radio 12v battery
    black radio ground
    orange radio illumination
    Please verify and we shall go from there
  5. #5 Re: New HU, no sound while running.
    Illinois
    GMOS - Radio - Didn't hook up the amp wire, as I couldn't find anything to hook it to, hooked up the mute wire.
    SWI- Check
    GMOS 14 pin - Didn't hook up the orange, as I couldn't find an illumination wire. Otherwise, check.
  6. #6 Re: New HU, no sound while running.
    Lala land
    You should have an amp turn on wire blue/white on your Hu harness , you will need to hook this up to make your Monsoon amp work otherwise no sound
    Illumination wire is also orange
  7. #7 Re: New HU, no sound while running.
    Illinois
    Fantastic, Thanks for the help! It works great, though I'm a little disappointed with Bluetooth quality, I will have to mess with the mic I guess.
  8. #8 Re: New HU, no sound while running.
    Lala land
    Glad I could be of assistance,did you figure out the lights problem yet?
  9. #9 Re: New HU, no sound while running.
    Illinois
    It had something to do with having the harness hooked up w/o the HU attached, as soon as I put the HU back in this morning and closed the doors the lights went out, everything is working perfectly again!
  10. #10 Re: New HU, no sound while running.
    London Ont, Canada
    disconnect that damn mute wire, its useless
  1. gurgle / running liquid sound when accelerating
    By chuy09 in forum 04+ Specifics
    Last Post: 02-17-2012, 07:09 PM
  2. name that sound
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2010, 11:46 PM
  3. new sound:)
    By beckys2000gt in forum General Tech Discussion
    Last Post: 07-03-2010, 06:19 PM
  4. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  5. sound
    By cletus in forum Audio, Security & Visual Electronics
    Last Post: 07-29-2009, 06:50 AM
