Thread: mounting depth on doors
Results 1 to 8 of 8
Nowak1981 mounting depth on doors 07-15-2008, 05:03 PM
JCG\'s-GTP Re: mounting depth on doors 07-15-2008, 07:13 PM
archemedes Re: mounting depth on doors 07-15-2008, 10:29 PM
Nowak1981 Re: mounting depth on doors 07-16-2008, 08:34 AM
archemedes Re: mounting depth on doors 07-16-2008, 10:20 AM
Nowak1981 Re: mounting depth on doors 07-16-2008, 11:29 AM
archemedes Re: mounting depth on doors 07-18-2008, 10:56 AM
jacobmh27 Re: mounting depth on doors 07-18-2008, 11:59 AM
  1. #1 mounting depth on doors
    Jul 2008
    Iowa
    I was curious what was involved in getting a set of 6.5's in the doors. Im thinking about putting some 6w3v3 woofers in the door. They have 4 3/16 mounting depth and I would need at least another inch or so to make some kind of fiberglass enclosure.
    I have no interest in making any modification to the door or door panel itself, I was thinking of building a baffle and fiberglassing a pocket with it. I dont know how long I am keeping this car due to the rust on the rear strut towers. So I need it to be unmodified so I can return the stock components when I trade it in. Which sucks cause I really like this car, Its my second one. Stupid rust.
  2. #2 Re: mounting depth on doors
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Well an eas way I think of doing it may be to use the foam baffles that Crutchfield sells and use that as a mold. As for the inch of clearance, I used 1-1/8th" piece and made spacer. Worked out really well. I'll try to dig up a pic if you want.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  3. #3 Re: mounting depth on doors
    Saraland Alabama
    make a spacer from mdf, mine is about an inch thick, and works great with my soundstream comps
  4. #4 Re: mounting depth on doors
    Jul 2008
    Iowa
    pics would be awesome. I figured I would have to make some spacers, my biggest worry was being able to fit such a large speaker in the door (depth wise) and be able to make a fiberglass enclosure on top of that.
  5. #5 Re: mounting depth on doors
    Saraland Alabama
    I don't care for putting enclosures in the doors, ones I have heard always buzz a little, just seal the door, and use it as the enclosure (dynamat will seal it)
  6. #6 Re: mounting depth on doors
    Jul 2008
    Iowa
    problem is the speakers are not open air and require only .15 cf of space so its not gonna be a huge enclosure.
    Kicker has some open air woofers but I just dont feel like I would get what I am looking for with open air.
  7. #7 Re: mounting depth on doors
    Saraland Alabama
    honestly unless you are going for a deeper bass, you probably won't hear a ton of difference if the whole door is sealed compared to a small enclosure, and if you want deep bass, kicker separates aren't really the right product
  8. #8 Re: mounting depth on doors
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Here is the write up with picture for the front doors
    http://www.grandprixforums.net/front_speaker.php
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  1. GPS Mounting
    By iflycessnas05 in forum General Tech Discussion
    Last Post: 06-26-2008, 08:36 PM
  2. ballast mounting
    By Toasty in forum Visual/Body Modifications
    Last Post: 03-31-2008, 12:40 AM
  3. How to make a nicer aftermarket radio mounting kit. [*]
    By s1795so2 in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 10:45 AM
  4. Lambo Doors?
    By scoobyydooooooo in forum Visual/Body Modifications
    Last Post: 02-02-2008, 02:39 AM
  5. Extending Depth of Console Pocket [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 02-02-2008, 12:30 AM
