Thread: New Front Speakers. What one Should I Choose?
Results 1 to 14 of 14
  1. #1 New Front Speakers. What one Should I Choose?
    SE Level Member Dabman's Avatar
    Jul 2010
    New York
    Hey Guys, I'm looking for new front speakers to replace my broken ones. Well one is broken so I figure I will just replace both. I'm looking to only spend around $50. More Bass would be nice but I know bass is almost non-exsistant especially in 5.25 speakers. Here is what I'm looking at:
    Polk:
    http://www.amazon.com/gp/product/B00...pf_rd_i=507846
    And
    Pioneer:
    http://www.amazon.com/Pioneer-TS-G13...ref=pd_sim_e_4
    03 GT, 35% all around, 5000k HID Fogs, Built-in GPS / Rearview Camera / DVD Player
  2. #2 Re: New Front Speakers. What one Should I Choose?
    Keller,TX
    Polks for sure.
  3. #3 Re: New Front Speakers. What one Should I Choose?
    i have those same polk's and the 6x9 one's in that modle and i love them and there cheap for what they are..
    SMGPFC Member #10
  4. #4 Re: New Front Speakers. What one Should I Choose?
    Jul 2010
    New York
    Hey guys, I'm thinking about going with the polks. I have 1 question though. How do I wire my new front speakers to the car? Seems like the tweeters and lower speaker are physically seperate. My problem is with the stock tweeter causing major static, so I do not want to run anything in parallel, just everything from the new speakers. Thanks for the help.
  5. #5 Re: New Front Speakers. What one Should I Choose?
    Keller,TX
    When you pull the door panel to swap out the factory speaker you'll see the wire for the factory tweeter, just unplug it and wire up the new ones.
  6. #6 Re: New Front Speakers. What one Should I Choose?
    GT Level Member dengnath's Avatar
    sorry but you are wrong.... i called crutchfeild and best buy. Both said to run your woofer wires into the crossovers that come with the new speakers, then run from the crossover to the new tweeters... i thought it sounded funny when hearing it but it works properly. The stock crossovers will not handle the new tweeters good
  7. #7 Re: New Front Speakers. What one Should I Choose?
    Keller,TX
    No you are wrong, reread his post.
    Quote Originally Posted by dengnath View Post
  8. #8 Re: New Front Speakers. What one Should I Choose?
    Jul 2010
    New York
    I'm not sure if you guys understand the question. I am transitioning from the stock "component" speakers, tweeters and mids seperate, to the all in one polks with the mid and tweeters built in.
  9. #9 Re: New Front Speakers. What one Should I Choose?
    the polks have tweeters in them,,just disconnect the stock ones and not worry about them
    SMGPFC Member #10
  10. #10 Re: New Front Speakers. What one Should I Choose?
    i was wrong... i thought he was replacing them with compnents..... sorry. I didnt think anyone would downgrade their speakers
  11. #11 Re: New Front Speakers. What one Should I Choose?
    Keller,TX
    Depending on the speakers it may not be a downgrade. He is moving from factory speakers to a high quality coaxial set, which will completely blow the factories away.
    Coaxial speakers do have some benefits, one is that high- and low-frequency sounds originate from the same point in space. This "point source" delivers the full range of sound frequencies in correct phase alignment, resulting in a smoother frequency response and improved clarity. This is a good thing considering most people who install a component set will mount the tweeters in generally poor locations, not taking into account speaker phasing and imaging.
  12. #12 Re: New Front Speakers. What one Should I Choose?
    Jul 2010
    New York
    I'm a super noob as far as audio equipment is concerned. Just wondering what all that coaxial stuff means? Can I just Plug and play into the wires that are already there?
  13. #13 Re: New Front Speakers. What one Should I Choose?
    Keller,TX
    Use the wires that are connected to the large speaker (woofer) to connect to your new speakers and just leave the factory tweeter wire unplugged. You will want to make sure that your new speakers are in phase with the other speakers in the car. If you get one speaker out of phase you will get a reduction in the systems bass output. There are several GP wire charts on the net just ind one and put + to + and -to -.
    A coaxial speaker simple means the sound radiates from the same point, with the high frequency drivers mounted in front of the lower frequency driver
  14. #14 Re: New Front Speakers. What one Should I Choose?
    ya in the 04 pluses they are in a crappy spot to start with.... i remounted my new polk tweeters higher..... such a difference... there location on the oringinals suck
  1. Front speakers
    By Edagimo in forum Audio, Security & Visual Electronics
    Last Post: 12-14-2010, 04:20 AM
  2. front speakers
    By dengnath in forum Audio, Security & Visual Electronics
    Last Post: 10-30-2010, 06:53 PM
  3. Need new front tires...help me choose
    By Smokin2000gtp in forum Tires & Wheels
    Last Post: 07-12-2010, 05:15 PM
  4. front speakers
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2009, 12:34 PM
