Thread: How to change speakers
Results 1 to 3 of 3
  1. #1 How to change speakers
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    I need to change the front speakers in my 96 gp se (special edition). but every time i have tried to take the iner door pannel off on any car iv hed, iv broke the pannel. Is there anyway to do this without breaking it? pictures would be great with a discription, so i can print it out and take it home with me. thank you.
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  2. #2 Re: How to change speakers
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
  3. #3 Re: How to change speakers
    I live here. TLSheff's Avatar
    wiki-answer is as follows:
    well you have to remove all the screws that you can see, once you do that theres four that you cannot see, ones in the top of the panel under the plastic where the seat belt goes in not all of the plastic just the middle cover its cliped in, anoth(pops right off with a flat head screw driver), then the gray plastic comes off when you depress the clips at the top and bottom and it should pop off there is a screw under that, another of the hidden screws is a torx im not sure of the size because the screw driver I used did not say but I think its around 20? its located in the bottom right of the handle where the far top Right of the speaker meets the handle, this screw is at an angle, you'll also have to remove your window button panel held with 2 smaller torx clearly visible, once you remove that there is a rather large torx screw under that you should find it quickly its not that hidden, after you remove all the screws the panel will still e rather tight from the clips you'll have to carefully remove these from the panel without breaking the panel, they wont simply slide off you'll have to replace these if you want factory tightness you can find some at pepboys or you can just forget about them and just screw the panel back on making it easier to remove in the future, also be careful not to over tighten any thing or else you'll strip the holes and you'll be in a world of trouble,
    good luck!
    Hope this helps...
  1. Speakers
    By EJRJR91 in forum Audio, Security & Visual Electronics
    Last Post: 09-04-2010, 05:01 AM
  2. Speakers
    Last Post: 06-07-2010, 07:18 PM
  3. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  4. new speakers
    By keenan00gtp in forum Audio, Security & Visual Electronics
    Last Post: 12-24-2008, 04:52 PM
