Thread: H. O. Alternator
Results 1 to 12 of 12
  1. #1 H. O. Alternator
    Pennsylvania, USA
    I'll keep this short and simple, I need an alternator that puts out more amperage, 160A might be fine, but for the love of god I CAN'T find a site that specifically denotes it will fit my car. I have an 05 GT, already did the Big 3 and plan on adding another amp, but with my existing setup I'm still getting noticeable dimming at max volume.
    This is the only site I found after searching the forum: Knukonceptz product detail for 04 GM 3.8L DELCO 200A ALTERNATOR
    But they seem kind of sketchy. I don't want to buy one and have it die on me a month later. Anyone have any links?
    I live in NEPA so even if there's a shop around my area anyone knows about, that would be helpful as well.
  2. #2 Re: H. O. Alternator
    Feb 2009
    Virginia
    Knu is a good brand. So what is it that you're doing that our world SPL competitor isn't? I'm pretty certain he's run a true 4kilowatts burp using the stock alternator just fine. I'm not trying to be "that guy" but I'm hoping we can save you a few bucks too
    11 is louder than 10!
  3. #3 Re: H. O. Alternator
    Nov 2009
    illinois
    checkout mechman.com or iraggi alternators.
  4. #4 Re: H. O. Alternator
    Pennsylvania, USA
    F&%*, I just typed a fricken paragraph and my computer BSOD'd on me >
    Basically I typed, I have double runs of 2 AWG for the big 3, crimped and soldered, all clean metal, the ground for the engine I skipped and went straight from the alternator casing to the chassis. It helped but my lights still dim from a 900 watt rms Kenwood amp, maybe the 8405, but not sure on the model. Is it inefficient?
    Maybe my stock alternator is just dying, but I can't think of anything else to try at this point except put in a bigger one.
    I checked out both of those sites too, mechman only had a 270A (way more than I need) for like $400, and iraggi doesn't have any alternators for Pontiac cars, just trucks, vans, and suv's.
    Thanks for the responses regardless, I'm still very happy I have experienced adiophiles helping me with this irritating issue
  5. #5 Re: H. O. Alternator
    Feb 2009
    Virginia
    You might be clipping your signal. Also, surface area is a big deal. If you aren't making good contact between the wire and the ground point then all that soldering won't help. Verify that the amp itself has a good grounding point too.
    Sometimes, trying to draw too much through a narrow point(bad connection) can also cause a voltage drop and dimming lights. Positive wires need good connections too. It's a pain in the butt but I've seen guys hit 150 decibels on stock alternators without problems
  6. #6 Re: H. O. Alternator
    All my wiring is from Knu based on audio buddy recommendations. While I'm not running a billion watts. I am pushing a single 5 channel amp and it'll make my ears bleed. Never dims a light, never an issue. Knu for the wiring, Boston for the rest.
  7. #7 Re: H. O. Alternator
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    I800 i know a guy that dose 151.2db on a stock alt =D
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  8. #8 Re: H. O. Alternator
    Pennsylvania, USA
    Sorry for the late response, I was on vacation in Ohio (:
    I've actually noticed my lights randomly dimming when i first turn on my car/ switch from drive to reverse and odd things like that as well, I kind of think that my stock alt itself is going bad...
    Plus I got my GP used at 60,000 as a rental car, so I'm not sure what kind of abuse it's taken
    Figured out today my AC no longer works, not sure if it's low fluid or what, butthis is getting irritating
  9. #9 Re: H. O. Alternator
    Feb 2010
    tampa
    I have a power bastards alternator 220 amp ill let go for 200 shipped
  10. #10 Re: H. O. Alternator
    Feb 2010
    tampa
  11. #11 Re: H. O. Alternator
    May 2008
    Winnipeg, MB
    I can't get rid of my 200A alternator. It was on a 1991 Olds 88, series 1 3800 engine. Only one offer of $80 in the past few years of trying to sell it and that just is not enough for a item that I paid $440 for.
    2007 Pontiac Grand Prix
  12. #12 Re: H. O. Alternator
    Feb 2010
    tampa
    go onto caraudio.com etc youll sell it fast
  1. Alternator?
    By Vagen in forum General Tech Discussion
    Last Post: 08-24-2009, 12:05 AM
  2. HO Alternator
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2009, 08:48 PM
  3. alternator
    By Slueth66 in forum General Tech Discussion
    Last Post: 01-29-2009, 10:05 AM
  4. Alternator ????????
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-27-2008, 11:01 PM
