Thread: H. O. Alternator
Results 1 to 12 of 12
  1. #1 Re: H. O. Alternator
    Feb 2009
    Virginia
    You might be clipping your signal. Also, surface area is a big deal. If you aren't making good contact between the wire and the ground point then all that soldering won't help. Verify that the amp itself has a good grounding point too.
    Sometimes, trying to draw too much through a narrow point(bad connection) can also cause a voltage drop and dimming lights. Positive wires need good connections too. It's a pain in the butt but I've seen guys hit 150 decibels on stock alternators without problems
    11 is louder than 10!
  2. #2 Re: H. O. Alternator
    All my wiring is from Knu based on audio buddy recommendations. While I'm not running a billion watts. I am pushing a single 5 channel amp and it'll make my ears bleed. Never dims a light, never an issue. Knu for the wiring, Boston for the rest.
  1. Alternator?
    By Vagen in forum General Tech Discussion
    Last Post: 08-24-2009, 12:05 AM
  2. HO Alternator
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2009, 08:48 PM
  3. alternator
    By Slueth66 in forum General Tech Discussion
    Last Post: 01-29-2009, 10:05 AM
  4. Alternator ????????
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-27-2008, 11:01 PM
