Thread: converting door speakers
Results 1 to 7 of 7
TNTSS converting door speakers 06-30-2008, 04:11 PM
archemedes Re: converting door speakers 06-30-2008, 10:18 PM
GeddyLee Re: converting door speakers 07-01-2008, 10:29 AM
archemedes Re: converting door speakers 07-01-2008, 10:31 AM
GeddyLee Re: converting door speakers 07-01-2008, 10:33 AM
archemedes Re: converting door speakers 07-01-2008, 10:47 AM
JCG\'s-GTP Re: converting door speakers 07-01-2008, 12:58 PM
  1. #1 converting door speakers
    Hey guys!!!
    I wanna put in 6 1/2" drivers into the doors....
    What is invovled, and did you have clearance issues wiht the
    window once installed?
    Wiz, Wideband O2, 78mm T/B, P&P SC, SSIC, P&P LIM, 3", 1.8CCRR's, CC push rods, Custom covers, SLP headers, Meziere Water pump 3" Magnaflow, Race Tranny, 20" Concept One Wheels, Coilovers, BMR F&R suspension, Custom Body and Paint, Custom interior and sound.
  2. #2 Re: converting door speakers
    GrandPrix Junkie
    Saraland Alabama
    make a spacer, or buy a plastic one from metra, I have soundstreams in mine, and no problems at all (and they are large)
  3. #3 Re: converting door speakers
    St. Louis Mo.
    My car had the Bose speakers in it. It had a plastic holder for the speaker that was secured to the door panel. When I upgraded to my 6.5" Memphis M speakers. I took out the plastic hold that held the 5.5" speakers and dremelled it out so it would fit the 6.5" speakers. It took a few tries to get it to sit below the section of the door skin that was rubbing against the outter part of the woofer. But once I managed to get past that, they worked fine.
    I am guessing GP's without the Bose speaker package do not have those nice plastic holders???
    James Shafer
    St. Louis MO
  4. #4 Re: converting door speakers
    GrandPrix Junkie
    Saraland Alabama
    mine had some, but they put the 6.5's against the door panel
  5. #5 Re: converting door speakers
    St. Louis Mo.
    Quote Originally Posted by archemedes View Post
    Aye correct, that is the part I had to work around. I cut deep into the plastic so that the speaker would sit lower in the cradle. And I then used my dremel tool to shave off the plastic of the door skin so it would not rest against the woofer. It worked out rather nicely. Granted I had white plastic stuff all over the place before it was all said done, but it doing that made it work
    James Shafer
    St. Louis MO
  6. #6 Re: converting door speakers
    GrandPrix Junkie
    Saraland Alabama
    mine the mounting surface was pretty thin
  7. #7 Re: converting door speakers
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    I cut the inside of the plastic housing out and made a 1" spacer for my kickers. The good thing about wood is you can sand it down at an angle for beter imaging. @ 1" I had no issues at all.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  1. Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    By Quicksilver_GP in forum How To Write-Ups/Tech Tips
    Last Post: 08-28-2013, 09:12 PM
  2. Speakers & Ipod
    By kahluatoo in forum General Tech Discussion
    Last Post: 06-02-2008, 11:56 PM
  3. Converting from a 1 bar to a 2 bar map.
    By TurboKent in forum General Tech Discussion
    Last Post: 03-16-2008, 02:10 PM
  4. Any way to make 6 1/2 speakers fit?
    By Deezul_AwT in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2008, 11:03 PM
