Thread: ??? on wireing harness
Results 1 to 6 of 6
  1. #1 ??? on wireing harness
    Destroys cars izup69's Avatar
    Iowa
    Ok my old headunit took a dump went out and got a new one. Now this new one will not power on unless I hook up the power wire(red) and constant 12v (yellow) on the stereo to the constant 12v coming out of the wiring harness.
    There is no power coming out of the power wire on the wiring harness.
    Yet my old headunit worked just fine. Went out and got another wiring harness thought something shorted out. Nope the new wiring harness has the same problem.
    So b4 I go out and spent the $180 on a good access gmos-100 harness that keeps everything. Was wondering what the problem could be. The first headunit I had was like 6 years old. Would that have something to do with it working and my new one not.
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  2. #2 Re: ??? on wireing harness
    Year make and model would be very helpful to determine which setup you have in the car. Model and make of new headunit could be helpful too.
  3. #3 Re: ??? on wireing harness
    Iowa
    sorry was kinda tired this morning. 06 grand prix obviously but stock system no onstar. New headunit is pioneer 8200bt I think something like that.
  4. #4 Re: ??? on wireing harness
    Feb 2009
    Virginia
    Simple solution is hook up to always-on 12V source. I believe that's the yellow wire?(somebody confirm that?) Add a switch in line and you don't have to deal with RAP. Otherwise, perhaps your aftermarket RAP isn't functioning correctly?
    But, just like always...trial and error for troubleshooting. That means confirming that wiring is run properly as well as crimped/soldered correctly too.
    11 is louder than 10!
  5. #5 Re: ??? on wireing harness
    Iowa
    yeh but if I hook it up to the constant 12v it will drain my battery it will be on non stop 24/7 365 never shut off. I was thinking about useing a fuse jump to hook it up to 12v off of a fuse of some sorts but I think im just gunna say f it and buy a good wireing harness
  6. #6 Re: ??? on wireing harness
    Feb 2009
    Virginia
    Quote Originally Posted by izup69 View Post
    That's why I said throw a switch in line to that.
    =======12v-always on=======SWITCH=====radio's yellow wire========
    You can turn it off/on yourself.
  1. Wheel Speed Sensor Wireing harness
    By packerfanjc in forum Tires & Wheels
    Last Post: 02-16-2011, 10:09 AM
  2. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  3. 2001 grand prix gt wireing problem
    By nascartech in forum General Tech Discussion
    Last Post: 10-08-2010, 10:20 PM
  4. wondering about wireing a fastory stereo to a amp
    By krimsonwolf in forum Audio, Security & Visual Electronics
    Last Post: 08-01-2010, 11:39 AM
  5. Afc 2.0 ext harness
    By zexed99gt in forum PCM Tuning
    Last Post: 12-08-2008, 09:30 AM
