why not just do two strips of white? one for signal and one for drl? i HATE amber.
I set up the fog light in my other car as signal/ drl/ fog. It is a Fiero and seemed like the best place for foglight is where the signal/ parking light used to be.
Here a white signal light is legal and I wanted to make sure the signallight could be seen. Wiith a halo the fog would need to be turned off anyway to easily see it from far away.
If you set the halo to be on all the time then just use 2 relays, one for each side to turn off the halo for the signallight. If you want to turn the halos off as well use 3 2way relays, one to turn halo on / off other 2 to flip the rail with signal-light (used this with my foglight on the fiero just so I could turn them off)
