Thread: Will this fob work?
Results 1 to 7 of 7
  1. #1 Will this fob work?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Ok, so this is the deal.My keyless entry has been screwin up for a while now.Its circuit board is now deceased.So i picked up 2 used key fobs for 5 bucks at a junk yard.They look identicle to mine, but are off of an impala (05 i think and they have the spot for the battery in a different place)First, will impala fobs work and second, how do you program one of these babys anyway???
    Any advice would be greatly appriciated, tanx
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  2. #2 Re: Will this fob work?
    check the part # on your old one's and the new ones to see if they match, then make sure the fcc# are different, if one of the new ones match the fcc# it wont work. then do a relearn of the fob after you know its the right ones.
  3. #3 Re: Will this fob work?
    redneck tennessee
    Thank you scottydoggs, Im gonna try it this week if my #s check out
  4. #4 Re: Will this fob work?
    Donating Users gtp239's Avatar
    ft myers fl
    what if i dont have an old one any way to find out what numbers i need?
    1998 gtp fwi, sd headers, overkill,3.4, poly mounts,p&psc
  5. #5 Re: Will this fob work?
    Adrian, MI
    Quote Originally Posted by gtp239 View Post
    Your FCC ID should be ABO-0204T. That's for a '98 GP. '97-'00 should use the same remote, 01+ used a different one.
  6. #6 Re: Will this fob work?
    ft myers fl
    thanks
  7. #7 Re: Will this fob work?
    the way i found my part # was i searched ebay for my year car and double checked a bunch of sales to make sure they were all the same #, and Google helped, just ask what the part # of anything and it will get you somewhere. it was my first stop. then found one i liked and ordered it up.
  1. will this work...
    By Myprixxx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-19-2010, 05:17 PM
  2. Best day at work ever.
    By Sheepdog in forum Off Topic Discussion
    Last Post: 04-03-2010, 04:29 PM
  3. cant get sub to work
    By CMURDAx in forum Audio, Security & Visual Electronics
    Last Post: 01-16-2010, 04:27 PM
  4. Will A 99 GTP DHP PCM work in a 98 GTP
    By pontiacGTP123 in forum PCM Tuning
    Last Post: 05-08-2009, 12:23 PM
  5. Will a 99 N/A gp maf work ok 98 GTP
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 05-07-2009, 12:00 PM
