Yup you can also swap the front panel over as well, Before you takeoff the front you have to make sure you disconnect the panel cables from the main board on the inside or else they will get ripped due to the small lenthg.
I think it's the bottom cover you open and youll see where they connect to the main board, Very easy to do.
If you can get the right socket for the screws holding it together it wont take very long either, usually less time then it takes to drive to the dealer![]()
