Thread: Mounting Amplifiers to Trunk Lid
Results 1 to 14 of 14
  1. #1 Mounting Amplifiers to Trunk Lid
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Hey everyone, I want to run this idea and get everyones opinion on it!
    So here goes. My larger amplifiers I used to have were stolen and were replaced with smaller amps that don't look right where the larger ams used to be mounted.
    Instead I want to mount both of my amplifiers to the trunk lid, one on either side of the lid with a centrally mounted engraved piece of acrylic that will hopefully look like this.
    [IMG][/IMG]
    Now I am sure your asking how I would mount such heavy items to the trunk lid. I have put some though into this. I am thinking about 3/8 or half inch plywood, something that will flex a little bit keep it tensile strength even when bent. I would bolt the plywood to the trunk lid which would give me a hard flat surface to mount both my amplifiers and imbed my plexiglass in the middle of the trunk. I would cover the whole thing with the charcoal carpet to match the trunk and hid all of the wiring underneath the plywood, in the frame of the trunk.
    I know it seems optimistic but the more I think about it, the more I think I can pull if off, but If I cant make it look good, than I wont do it. I want everyones ideas on functionality, construction and appearance.
    Thanks!
    Infinity all around.
  2. #2 Re: Mounting Amplifiers to Trunk Lid
    Its not that, its why would you mount any heavy things beyond the rear axle?
  3. #3 Re: Mounting Amplifiers to Trunk Lid
    Quote Originally Posted by That Canadian Guy View Post
    The amplifiers were already mounted behind the rear axle, and who cares? The damn thing is a grand prix with 200hp, not looking to drag race here. Im not worried about weight distribution.
  4. #4 Re: Mounting Amplifiers to Trunk Lid
    then uninstall your sway bar links.
    only race cars need those.
    Just kidding.
    Your gas struts wont be able to hold your lid up if you mount them there.
    Up to you really.
    You say your last ones got stolen so I dont see why would want to be advertising them every time you pop the trunk.
  5. #5 Re: Mounting Amplifiers to Trunk Lid
    Feb 2009
    Virginia
    I like my mounting location under the rear deck/speaker deck. Nobody knows but me.
    11 is louder than 10!
  6. #6 Re: Mounting Amplifiers to Trunk Lid
    MO
    Quote Originally Posted by I800C0LLECT View Post
    I like my mounting location under the rear deck speaker deck. Nobody knows but me.
    And the little kids you keep in there. I'm with Matt, why advertise them if theyre gonna get stolen
    <brandonl2000> LMAO D!!
  7. #7 Re: Mounting Amplifiers to Trunk Lid
    Feb 2009
    Virginia
    Quote Originally Posted by ZR1Vette09 View Post
    Exactly right! Nobody hears it but me...so why do I need to show them?
    I will say that there's a void in the trunk lid that wouldn't be a bad spot to hide them. However, I'd hate to deal with the wires and setup of the amp in there. You also have to deal with the deck lid weight becoming very cumbersome for the lifting mechanism. You'll need a hefty upgrade on those gas shocks.
  8. #8 Re: Mounting Amplifiers to Trunk Lid
    Well the first time they were stolen they had no idea they they were in there, I was in a parking lot. Not only that but if i open the trunk, the subwoofers are going to be painfuly obvious, so might as well make it look good Second, I was worried about the gas shocks but did a few tests with some free weights and there isn't an issue at all with the weight. Even closing it wasn't too bad. Ive put a lot of thought into this just wanted to see if anyOne had some good ideas on how to make this possible.
  9. #9 Re: Mounting Amplifiers to Trunk Lid
    MO
    Sounds like you've got a plan. If you don't mind the risk, then go for it.
  10. #10 Re: Mounting Amplifiers to Trunk Lid
    2003 SSEi did this on his 93 Bonneville. Had to max out the torque bar to hold the lid up and when it would be shut..you could loose anything that was laying in the path. It makes a lid very heavy overall.
    I mounted the amp up under the rear deck like 800 did. Works great, looks great when you bend over and see it, out of the way, less wiring and it's fixed. There's no potential for it to be coming loose when the lid is constantly closed.
  11. #11 Re: Mounting Amplifiers to Trunk Lid
    I suppose its somewhat reassuring that someone has done this before. I feeling pretty confidant in that I want to do, the most difficult part is going to be bolting the plywood to the trunk lid frame. 6 bolts with lock washers. This will hopefully contour the the plywood somewhat to the trunk lid itself. Ill mount the amplifiers directly to the plywood itself and run the wiring underneath. My amps arnt massive and I would would mount them low on the trunk lid to keep the center of weight down.
  12. #12 Re: Mounting Amplifiers to Trunk Lid
    I think I decided how I am going to make this happen. I am going to line the trunk lid with fiberglass and mount it to the deck lid. I will bondo two flat areas so I can mount my amplifiers to them and run all of the wiring. I will build an MDF rectangle around each amp and then make a second layer over the MDF so the ams are flush with that layer and all the wiring will be sandwiched between the two layers. Then sand and finish with carpet.
  13. #13 Re: Mounting Amplifiers to Trunk Lid
    SE Level Member djwright1980's Avatar
    tennessee
    I have done flush mount monitors in a decklid.I would sugest monting amps to mdf with nut and bolt before mounting to decklid.also take into consideration that trunks do sometimes leak especially if you have a spoiler recheck all seals.water and electronics don't mix.
  14. #14 Re: Mounting Amplifiers to Trunk Lid
    Quote Originally Posted by djwright1980 View Post
    Good point on the leak, ill have to silicone the hell outta it before hand.
  1. Mounting HID ballasts?
    By Frank217 in forum Visual/Body Modifications
    Last Post: 07-24-2010, 06:39 PM
  2. PCM mounting
    By grannyprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 03:50 AM
  3. Mounting subwoofer in cabin's trunk door.
    By Matthew in forum Audio, Security & Visual Electronics
    Last Post: 08-14-2009, 08:06 PM
  4. Mounting Kit??????
    By kingbrentdwyer in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2008, 02:08 AM
  5. GPS Mounting
    By iflycessnas05 in forum General Tech Discussion
    Last Post: 06-26-2008, 08:36 PM
