Take off the ring from around the ignition.
Grab the bottom of the center stack below the cubby hole and slide your hands to the sides.
Pull gently until it starts to come out.
Work your way up.
Unplug your D.I.C.
You have now successfully removed the center stack trim.
*You may need a flat head to help you out especially with the ignition ring.
