Thread: LED Brake light strips
Results 1 to 20 of 20
  1. #1 LED Brake light strips
    Rockford, IL
    In the how to threads there is a post on there about hooking up a 4th brake light using a 24" LED strip. I am thinking about hooking up 2 12" LED strips to the brake lights so that they come on with the brake lights then blink with the turn signals. My questions is has anyone done this?
  2. #2 Re: LED Brake light strips
    Windsor (ON) Canada
    I've been thinking the same thing... I was looking around the NET, and found this pic of Geddy Lees car (a moderator on here). Curious as to if this acts as a 4th break light
  3. #3 Re: LED Brake light strips
    SE Level Member hinkaj02's Avatar
    fort wayne, Indiana
    i think you can just cut into the power wire coming from one of your taillights and it should work.
    ------2004 GTP Comp G------
    20" Verde Black Ice rims, inferno hood, spoiler, air dam. exhaust and tips are next upgrade along with t* stat pugs and wires upgrade soon enough.
  4. #4 Re: LED Brake light strips
    Windsor (ON) Canada
    Quote Originally Posted by hinkaj02 View Post
    I'm wondering if the strip it would actually get BRIGHTER when you press the brake, or would is just stay on.
    Im calling out Geddy Lee!!!!!!! lol.... id really like to know how he did this, and if its functional
  5. #5 Re: LED Brake light strips
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    just get two strips and splice each one into the turn signal and boom your done
  6. #6 Re: LED Brake light strips
    Jul 2010
    Minnesota
    Here's what I did on my old Monte, just wired them into the brake lights. I never wanted it to be used as turn signals
  7. #7 Re: LED Brake light strips
    Rockford, IL
    I wanna hook mine up to the turn signals as well. I just didn't know if it would cause a hyperflash like the LED bulbs do or if it would just work fine. Looks like I am gonna just have to test it and see what happens.
  8. #8 Re: LED Brake light strips
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    IMHO it would look ok if the two seperate strips met together. When theres a gap it just looks off some how
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  9. #9 Re: LED Brake light strips
    GT Level Member Lougp05's Avatar
    Long Island,New York
    that would look good with turn signals
    <>Lou<> 05 GP,Black,8000k HIDS,FLowmaster Exhaust,Intake,20% tints.
  10. #10 Re: LED Brake light strips
    Jul 2010
    Minnesota
    The ones on my Monte would have matched the tail lights better but I already tinted them and they were dark as hell. Like dark to the point where you could barely see them light up in the day time
  11. #11 Re: LED Brake light strips
    Windsor (ON) Canada
    I was behind a big dodge truck the other day and had one solid red line under his tailgate, and one half flashed with his turn signal (so obviously two 24" strips laid together) it looked pretty sick. Ill be doing this for sure once it gets warmer.
  12. #12 Re: LED Brake light strips
    Quote Originally Posted by Colossus View Post
    they make strips that do that already that are one piece. you can find them all over the place. its just how they are wired that makes the difference.
  13. #13 Re: LED Brake light strips
    Rockford, IL
    That's the fire and ice bar. I think chamilton89 installed one on his. Looks nice but from what I found they are pretty pricey. I got the 2 12" strips for free from a buddy that was going to use them then decided not to. Hopefully this weekend I can get the car in the garage and get them on.
  14. #14 Re: LED Brake light strips
    GTP Level Member
    springfield IL
    dont see why you cant you the third break light wires.....???
  15. #15 Re: LED Brake light strips
    GT Level Member EJRJR91's Avatar
    Nanuet, NY
    i did mine, but i wired it to the third brake light (high-mount) so that way itd only go on when i hit the brake, i didnt want it to stay on while driving or go on with the turn signals although i couldve wired it that way if i wanted bc my set up is two 12 inch led strips with their own wires, they were sold together in the same package, i just put them end to end and ran the lights behind the normal brake lights nd thought where the wires go. Then i added on a long strip of wire to the positive and negative wires and then rand them all the way around up to the high mount brake light nd tied them in
  16. #16 Re: LED Brake light strips
    Rockford, IL
    Well I got mine hooked up over the weekend. I was able to hook em up to the brake and turn signals. They don't come on with the lights so I am golden. The install was pretty easy, only problem I ran into was frozen fingers. Gotta love Northern Illinois winters. Soon as the wife finds the camera I will have to get some pics.
    Nice work ejrjr, looks good!
  17. #17 Re: LED Brake light strips
    Windsor (ON) Canada
    Quote Originally Posted by Lofty View Post
    Could you unscrew one of your tail lights and show how you wired them up?? It would be much appreciated!!!
    Thanks in advance!
  18. #18 Re: LED Brake light strips
    Rockford, IL
    Thanks in advance!
    I will definitely do so. I just used the snap wiring splices just to do it quickly cause it was cold out so, I need to take them apart again to solder everything together.
  19. #19 Re: LED Brake light strips
    Ocala, FL
    Yep I did that on my gt, haven't yet done it on my gtp. Not sure if I will or not.
    Wired it into my third brake light, wasn't after trying to make it work with the turn signals. Though, I may do that in the future, the extra light is kinda nice when you have dark tinted tails.
  20. #20 Re: LED Brake light strips
    Nanuet, NY
    thanks lofty, it was a little messy going all the way up to the third brake light, i might rewire it to the regular brake lights just to simplify things, i dunno about the turn signals tho, i feel like thats a lil much for me but thats just a personal preference
  1. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  2. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  3. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
  4. Third Brake Light & LED's
    By Metallistar in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2009, 11:06 PM
