Thread: Retrieving Radio Security code
Results 1 to 7 of 7
cogsracing Retrieving Radio Security code 01-12-2011, 08:43 AM
donmega Re: Retrieving Radio Security... 01-12-2011, 02:34 PM
Fivefingerdeathpunch Re: Retrieving Radio Security... 01-12-2011, 02:39 PM
cogsracing Re: Retrieving Radio Security... 01-13-2011, 01:20 PM
Fivefingerdeathpunch Re: Retrieving Radio Security... 01-13-2011, 03:56 PM
cleangtp Re: Retrieving Radio Security... 01-13-2011, 04:48 PM
donmega Re: Retrieving Radio Security... 01-15-2011, 02:32 PM
  1. #1 Retrieving Radio Security code
    Maryland
    New 98 GTP owner.
    I know there is a security code for the radio.
    The owner I got the car from doesn't know the code---never had to use it.
    How do you retrieve the code BEFORE you need to use the code?
    I've seen the thread about getting the code AFTER you lock up the radio.
    Is there a button sequence to display the code BEFORE you lock up the radio--battery disconnect etc????
  2. #2 Re: Retrieving Radio Security code
    GT Level Member donmega's Avatar
    St louis, mo
    not with out a diagnostics machine.
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  3. #3 Re: Retrieving Radio Security code
    Quote Originally Posted by donmega View Post
    wrong.
    here type this code in, it works for me, its a DEALER code.
    put in the numbers 510
  4. #4 Re: Retrieving Radio Security code
    Maryland
    Thanks.
    I'll give it a try.
  5. #5 Re: Retrieving Radio Security code
    ok let me know if it works
  6. #6 Re: Retrieving Radio Security code
    Banned
    Mansfield, Ohio
  7. #7 Re: Retrieving Radio Security code
    St louis, mo
    you can try that as well. i looked it up in alldata and that was the procedure they gave so...... whatevers fastest and easiest though
  1. Security light
    By Soviet in forum Audio, Security & Visual Electronics
    Last Post: 08-16-2010, 06:45 PM
  2. Security system
    By musiknjoyr in forum Audio, Security & Visual Electronics
    Last Post: 12-09-2009, 10:43 AM
  3. Security
    By Bob8205 in forum Introductions/Noob Questions
    Last Post: 08-31-2009, 06:43 PM
  4. OEM Security LED
    By Lion29GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 01:47 AM
  5. Security Relearn
    By 04CompG in forum General Tech Discussion
    Last Post: 09-12-2008, 05:25 PM
