Thread: Steering wheel control interface install help!!!!
Results 1 to 20 of 30
blortz Steering wheel control... 12-29-2010, 12:39 AM
rynoman03 Re: Steering wheel control... 12-29-2010, 12:48 AM
triebenbach07 Re: Steering wheel control... 12-29-2010, 12:54 AM
blortz Re: Steering wheel control... 12-29-2010, 03:52 PM
VinnieGTP Re: Steering wheel control... 12-31-2010, 02:03 AM
beck Re: Steering wheel control... 01-06-2011, 09:47 PM
thunder71173 Re: Steering wheel control... 01-06-2011, 10:26 PM
nickbuol Re: Steering wheel control... 01-06-2011, 11:33 PM
BillBoost37 Re: Steering wheel control... 01-07-2011, 07:48 AM
beck Re: Steering wheel control... 01-07-2011, 02:56 PM
thunder71173 Re: Steering wheel control... 01-07-2011, 03:01 PM
onetyme77 Re: Steering wheel control... 01-10-2011, 07:14 PM
thunder71173 Re: Steering wheel control... 01-10-2011, 07:48 PM
blortz Re: Steering wheel control... 01-15-2011, 11:42 AM
blortz Re: Steering wheel control... 01-15-2011, 11:48 AM
thunder71173 Re: Steering wheel control... 01-15-2011, 01:32 PM
Carpepoon Re: Steering wheel control... 01-15-2011, 02:34 PM
Carpepoon Re: Steering wheel control... 01-15-2011, 02:47 PM
blortz Re: Steering wheel control... 01-18-2011, 01:44 PM
SNeitzel Re: Steering wheel control... 01-18-2011, 04:14 PM
nickbuol Re: Steering wheel control... 01-28-2011, 12:42 AM
thunder71173 Re: Steering wheel control... 01-28-2011, 05:56 AM
nickbuol Re: Steering wheel control... 01-28-2011, 10:14 AM
BillBoost37 Re: Steering wheel control... 01-28-2011, 10:56 AM
MidnightBlue Re: Steering wheel control... 01-28-2011, 10:59 AM
nickbuol Re: Steering wheel control... 01-28-2011, 11:46 AM
MidnightBlue Re: Steering wheel control... 01-28-2011, 11:48 AM
nickbuol Re: Steering wheel control... 01-28-2011, 12:20 PM
BillBoost37 Re: Steering wheel control... 01-28-2011, 12:56 PM
nickbuol Re: Steering wheel control... 01-29-2011, 06:02 PM
  1. #1 Re: Steering wheel control interface install help!!!!
    Grand Blanc, MI
    Forgive my last post, the connections are the same whether you have Bose or not.
    There should be 4 connections you have to make from the Pac, one is the plug that goes into the jack of the radio.
    The other 3 are ground (black), power (red) and your audio control wire (green)
    Connect black to ground, and red to your 12v switched wire (same wire as you used to connect your radio)
    For the audio control wire this should help:
    Search
    Whether you have bose or not the wire you need to connect the green wire to the wire coming out of pin 17 on your haness. (refer to the photo) Follow the directions on your chart given by the pac unit as to which wire to connect to (it should give you a color reference as well) and it will tell you if you need to cut the brown or violet looped wire coming out of the pac unit as well. Sorry I have a '07 and use a different pac unit so my chart doesn't have your vehicle on it.
    Once you have it connected, you go through the programming process.
  1. Steering Wheel control wires
    By bacampbe in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2010, 01:00 PM
  2. Malfunctioning Steering Wheel Interface?
    By SliceTheRice in forum Audio, Security & Visual Electronics
    Last Post: 08-12-2010, 02:05 PM
  3. Steering wheel interface
    By Autio in forum Audio, Security & Visual Electronics
    Last Post: 10-16-2008, 10:30 AM
