Thread: How would i go about installing this?
Results 1 to 9 of 9
  1. #1 Re: How would i go about installing this?
    Nov 2009
    illinois
    right now its setup like this.
    The HU has the rear/sub out option where it can change between the two. Its set to sub out and my sub amp is using that pre out. that leaves the front preout which my 4chan amp is Y'd off of that preout.
    i already have the dedicated sub out but only one. Could i Y off that and put in another mono amp like i already have? These amps cant be chained together. So looking at what you said im running option one but the amps only have rca inputs no outs. Thats where im confused on what to do. Would i switch to option 2 then? And if i do switch to option 2, that means i have enough preouts for the 4chan and 2 sub amps right? i miss having my fade and balance adjustments :P
  2. #2 Re: How would i go about installing this?
    SE Level Member iceman977th's Avatar
    KY
    Quote Originally Posted by 2000GTGP View Post
    Either way, you're going to have to send a second signal to the sub amplifiers. It's your choice if you want fade options or not. The way you have it now is just fine. Does the sub amplifier have a second set of RCA jacks? If so, you should be able to run it from there. If not, then Y-split is probably your best option.
    2001 Grand Prix GT Sedan Silver :: Sony CD-GT54UIW :: Clarion EQS746
    2x Audioque SDC2.5 12" D4 + Audiopipe AP1500.1D :: 4 cu ft @ 32Hz, 1500w @ 1ohm
    Crescendo CCX65 Doors :: Pioneer 6x9 Rear :: Cadence CRS-Z9 4ch
  1. Installing new HU
    By CMURDAx in forum Audio, Security & Visual Electronics
    Last Post: 06-13-2010, 12:00 AM
  2. installing HUD
    By joshsGT in forum Audio, Security & Visual Electronics
    Last Post: 03-16-2010, 10:47 PM
  3. Need help installing HUD
    By nabil237 in forum General Tech Discussion
    Last Post: 11-21-2009, 09:22 AM
  4. installing LOC
    By Preston in forum Audio, Security & Visual Electronics
    Last Post: 09-12-2008, 12:08 PM
  5. Installing HUD?
    By retski420 in forum General Tech Discussion
    Last Post: 03-17-2008, 02:29 PM
