Quote Originally Posted by 2002red View Post
Thanks Iceman. Is the Walmart mount much different than the Schosche kit that Sonic supplies?
I did mean 10 on the sub, didn't realize it had 2 voice coils though. I was just looking at the 2 ohm and an amp that wouldn't overpower it. Told you I needed help I'll check out the Audiopipe.
If I throw a new head into the mix rears are out of the budget for now.
Thanks
I have no idea. There's a GM mount kit that Walmart keeps in stock, but the one specifically for 01-03 GP's I think they recommend to special order, but I used the earlier model one, once you find the right bracket, will fit into the '01-'03 mounts
Haha no problem. That headunit looks fine for what you need, just make sure you have a mount kit for it.
Looked at the Audiopipe, it's class D as opposed to others I've seen. Would you suggest running it at 4 ohm? Would run cooler and should be enough output since it is class D?
If they are like the other Audiopipe amplifiers, then you should be fine at 1 ohm. Most A/B class amplifiers are not meant for 1 ohm applications, or even 2 ohm. I haven't found much on the lower wattage versions, but the upper wattages of the same class have had excellent reviews for the price. Run it at 1 ohm, with your subwoofer running parallel (one coil wired up to the other) and you should be okay. Also, make sure you have money for a wiring kit; for something like that, you should be fine with 8 gauge wiring.
