Thread: add hud to 92 grand prix?
Results 1 to 19 of 19
  1. #1 add hud to 92 grand prix?
    detroit, mi
    Can you add a hud to a 1992 2 dr grand prix se?
    I just got this car...don't know much about them yet.
    I found a cheap used heads up display for a 90 grand prix on ebay. Just wondering if the wiring is there so it's a plug and play?
    Thanks for any info.....Brian
  2. #2 Re: add hud to 92 grand prix?
    Donating Users mystic231's Avatar
    Michigan
    Keep searching E-Bay for a factory manual. You'll find the answer in there along with what you'll need to do it. I'm assuming it's plug and play but you'll also need the different dash componets.
    Factory manuals go for $30-70 on E-Bay; new they were $125 plus, so they can't be beat.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  3. #3 Re: add hud to 92 grand prix?
    SE Level Member 1992GrandPrixSE's Avatar
    Central Ohio
    Hello,
    The short answer to this question is...yes you can. I did this with success in my car. You will need the following parts:
    (1) HUD projector
    (2) HUD metal tray
    (3) HUD dashpad (the dashpad has a hole cut in it for the projector)
    (4) HUD dimmer switch (this includes a cable that connects to the projector for adjusting the height of the display on the inside of your windshield)
    (5) Modified plastic housing that surrounds your headlight and wiper switches (there is a hole in the housing underneath the wiper switch - this is where the HUD dimmer switch mounts)
    (6) Mounting hardware (be sure to retain ALL of the screws if you pull these parts out of a junkyard car)
    Your car *should* be pre-wired for the HUD projector and HUD dimmer switch. The easiest way to tell if your car has the wiring is to remove your wiper switch pod. Look for a wiring harness and plug in the recess behind the switch. It should be folded over and taped together. This is the harness that plugs into the HUD dimmer switch. Assuming you can get the parts from a junkyard car, this is a very easy thing to do. Some folks have cut holes in their dashpads and stuff like that, but I'd just recommend looking for these cars in yards. If you actually get moving on this project and need more specifics, PM me. I'd be glad to help. Dude, that HUD is the COOLEST thing once you get it installed and working.
    If you want to install a Driver Information Center (DIC), I can help with that too. Good luck! Nice to see another 1st gen W-body owner looking to improve their ride.
    My other car is a Trans Am. No really, it is.
  4. #4 Re: add hud to 92 grand prix?
    SE Level Member mikefeelsgood's Avatar
    madeira, ohio
    I've been really wanting to do this too! HUD is so awesome. Its like piloting an F22 (or something like that XD). I so wish my trans am had it. I have no idea why they never came with it :P
  5. #5 Re: add hud to 92 grand prix?
    Apr 2009
    Wausau, Wisconsin
    I thought the recent Trans Am had it?
  6. #6 Re: add hud to 92 grand prix?
    Apr 2009
    Wausau, Wisconsin
    Never mind looked it up...
  7. #7 Re: add hud to 92 grand prix?
    madeira, ohio
    well you probably thought that because it would ONLY make sense that it did!
    '95 GPSE-daily driver(planning on L67/282 swap)
    '91 Firebird-race car(selling :[ )
    '92 Kawasaki Ninja-just in case I want to die
  8. #8 Re: add hud to 92 grand prix?
    Apr 2009
    Wausau, Wisconsin
    Did any other GM RWD car have it?
  9. #9 Re: add hud to 92 grand prix?
    madeira, ohio
    not that i know of right off hand. i think the C5 corvettes had it. but im not sure. i only have experience with the C4 vettes. and im pretty sure some Cadillacs had it too
  10. #10 Re: add hud to 92 grand prix?
    madeira, ohio
    im planning on doing the L67/282 swap. does anyone know if the HUD will work with that setup? if it wont, then i dont want to put all the HUD stuff in and then have it not be functional once the car gets to screamin haha
  11. #11 Re: add hud to 92 grand prix?
    SE Level Member beck's Avatar
    MI
    I'll probably pick up the HUD stuff and add it to the gf's grand prix in the next week. Anyone got pics of a functional DIC? Is that something worth adding as well?
  12. #12 Re: add hud to 92 grand prix?
    Dec 2010
    ala
    yes ive been wanting to try that out as well found an intact unit in a 93 gtp at the boneyard . i have a 2002 so it should work shouldnt it???
    i have a crack in my current windshield so i can grab the windshield from the car as well.... understood all your instructions but not quite clear on the metal tray or the dimmer switch those should be on the car in the junk yard..
  13. #13 Re: add hud to 92 grand prix?
    Quote Originally Posted by anlo View Post
    No. It will not work and neither will the windshield. 2 different body style. 9 years apart
  14. #14 Re: add hud to 92 grand prix?
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    try this. theres links in the second post
    http://www.grandprixforums.net/hud-c...-gt-14542.html
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  15. #15 Re: add hud to 92 grand prix?
    MI
    I'm planning on running to the scrapyard to grab the parts for the HUD and DIC in the morning. What all do i NEED for the DIC? The HUD seems pretty straight forward- already looked and the wires are there. Just got done doing the intake gaskets today, and just trying to make this a better car all the way around.
    Thanks
  16. #16 Re: add hud to 92 grand prix?
    Donating Users Dboy23's Avatar
    Aug 2008
    Michigan
    My old XLR used to have it, I know some C6 Vette's have it also.
    *sig is too tall*
  17. #17 Re: add hud to 92 grand prix?
    Jul 2010
    Lansing IL
    im glad i stumbled on this thread! ive been wondiering that too before. i have the factory repair manuals so im going to start looking it all up
  18. #18 Re: add hud to 92 grand prix?
    Dec 2008
    Lawndale, CA
    Wite up for the HUD.
    ...Gearhead's NetGarage...
  19. #19 Re: add hud to 92 grand prix?
    Jul 2010
    Lansing IL
    NOT TRYING TO THREADJACK
    heres a link i found for doing a 1994-1996 (since the dash is different and so is the HUD wiring)
    HUD DISPLAY/INSTALL/Wiring
  1. 99' grand prix se 3.1 v6
    By kittie1342 in forum Introductions/Noob Questions
    Last Post: 05-25-2009, 09:31 PM
  2. New Guy with '04 Grand Prix GTP
    By NSUstud in forum Introductions/Noob Questions
    Last Post: 10-01-2008, 07:44 AM
  3. LS6 in Grand Prix
    By Ryan D. in forum Off Topic Discussion
    Last Post: 06-30-2008, 08:58 AM
