Joe, I ran 3 Punch 15's, a 600 watt, and a 800 watt amp on mine with no problems. You'll be fine. When you go to install your head unit, watch out for the clips on the back of the dash trim. some will pop off and fall in your dash. But, don't get discouraged because most likely they'll faal to the bottom. Pop off the cover under the dash and they'll be there. Hit on the plastic under the steering column and if any are sitting in that area, they'll go ahead and drop also.
