Thread: Big Q
Results 1 to 20 of 37
  1. #1 Re: Big Q
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    really a deck install should at the most take about 30 minutes, even for a first timer.
    As far as electrical issues, there should be none, maybe slight headlight dimming but you will be alright.
    if you are worried about dimming, then do the big three. which is upgrading the wire size, from alt to batt, batt to chassis ground, batt to engine block ground.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  2. #2 Re: Big Q
    May 2008
    Portsmouth, NH
    Dude, your setup should run just fine. You should notice a LITTLE headlight dimming (probly just enough that YOU'LL notice and it'll end up pissing you off... did with me), In addition to upping the wire size, I'd recommend getting a capacitor or mounting a second battery in the trunk... depending on your needs/preferences. These Electrical upgrades/add-ons will help reduce the immediate drain to your alternator/battery. I personally have 1600 watts run off my stock electrical and with my cap I haven't noticed any sort of power drain of any kind, including headlight/domelight dimming. Good luck with your install.
big
