The question is can/could i use a mini fuse tap on the power sun roof fuse in the fuse panel to get the switched 12+ accessory power that the radio needs to cut on and off.(the fuse is rated @ 20 amps)if you want to know.
Yes, you can do that.
Originally Posted by ham4864
o and yes i will replace the factory speakers
When you decide to replace your factory monsoon system, I'll buy the speakers from you.
