Thread: switched accessory tap
Results 1 to 13 of 13
  1. #1 switched accessory tap
    SE Level Member ham4864's Avatar
    Nov 2010
    usa
    Hi all i am hooking up a after market head unit in my 2004 grand prix with monsoon system.
    i don't care if i lose RAP
    i don't care much for the chime
    i don't have onstar
    i also know about the date will be lost on the DIC also
    i will disconnect the monsoon system and run new speaker wire,constant 12+/ground and accessory wire.
    The question is can/could i use a mini fuse tap on the power sun roof fuse in the fuse panel to get the switched 12+ accessory power that the radio needs to cut on and off.(the fuse is rated @ 20 amps)if you want to know.
    o and yes i will replace the factory speakers
    WhatAPrix
  2. #2 Re: switched accessory tap
    Jul 2010
    Indiana
    Don't take my word for it cause I'm just a n00b but I believe I heard other people saying that they did this. My guess is you would be fine.
  3. #3 Re: switched accessory tap
    West Side Michigan
    My cousin used the sunroof fuse to work for his aftermarket unit, even though it was on an Impala, same concept, I don't see why you couldn't.
  4. #4 Re: switched accessory tap
    St. Cloud, MN
    Quote Originally Posted by ham4864 View Post
    Yes, you can do that.
    When you decide to replace your factory monsoon system, I'll buy the speakers from you.
  5. #5 Re: switched accessory tap
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    I tapped into that fuse to power my radar detector so I don't see why not
    2004 GTP CompG - 3.6" ZZP MPS, K&N CAI, 180* Tstat, SSAC Headers, ZZP Flex, high flow cat, borla exhaust, DHP/danthurs tune, AL104s, ZZP Wires, alt re-wire, slotted/drilled rotors, 35% tint, alpine amp + sub
  6. #6 Re: switched accessory tap
    Nov 2010
    usa
    ok now what is the safest way to tap.thanks for all your help.
    1.buss-mans add a fuse
    2.splice the wire itself(solider and shrink)
    3.t tap (with inline fuse)
    4.the little clip over the fuse method
    WhatAPrix
  7. #7 Re: switched accessory tap
    Jul 2008
    Nashville, TN
    Add-a-fuse is the simplest for sure... no messing with the factory wiring and all you need to do is run the wire to the fuse box. That's what I'd do.
  8. #8 Re: switched accessory tap
    Nov 2010
    usa
    i was just reading that the add-a-fuse things are only rated 10amps.The only switched source in the 04 grand prix fuse panel that i can recall is the sunroof fuse and that is rated 25amps.So now i don't want to use that as a fuse tape i may just use the ignition wire.I would have done this all ready but man its getting cold oust side and i dont have enough room in my room car garage.
    WhatAPrix
  9. #9 Re: switched accessory tap
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    you could do something like this and just run an inline fuse to the radio
  10. #10 Re: switched accessory tap
    Nov 2010
    usa
    holy geeezzz batman.is that the grand prix.Can i steel that idea.
    WhatAPrix
  11. #11 Re: switched accessory tap
    Nov 2009
    steal what idea? what are talking about with that batman grand prix stuff?
  12. #12 Re: switched accessory tap
    Nov 2010
    usa
    nothing just a joke.never mind
    WhatAPrix
  13. #13 Re: switched accessory tap
    Nov 2009
    what did you mean? I want to know
  1. accessory belt
    By 98regalgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2010, 08:56 PM
  2. new Gun Accessory
    By RedGTX in forum Off Topic Discussion
    Last Post: 01-14-2010, 05:51 AM
  3. Switched Ignition Source
    By Blackhawk in forum Audio, Security & Visual Electronics
    Last Post: 11-15-2009, 05:51 PM
  4. 12volt switched source?
    By nyydmb12 in forum Audio, Security & Visual Electronics
    Last Post: 10-19-2009, 06:45 AM
  5. Accessory plug in
    By nrfitchett4 in forum Audio, Security & Visual Electronics
    Last Post: 04-14-2009, 06:15 AM
