Thread: Making a relay harness for HID's (For Matt)
Results 1 to 5 of 5
  1. #1 Making a relay harness for HID's (For Matt)
    Never Never Land
    Yesterday in the chat I was asking about a relay harness for my new HID's..matt said to just make one so i figured what the hell...ill spend about as much if i bought a harness and ill have plenty of wire/connectors left over if i need to do another one. This is where I need you Matt, how do i wire this up?
    My terminals are as follows...
    (30) "terminal for lights or horns"
    (87) "terminal for power source" This is just my positive wire from the battery right?
    (86) "terminal from switch"
    (85) "terminal for relay ground wire" This is just a chassis ground right?
  2. #2 Re: Making a relay harness for HID's (For Matt)
    do as it says lol.
    30 goes to the positive on your lights.
    87 goes to battery with inline fuse.
    86 goes to positive switched side of a switch of some sort.
    85 is a ground.
    Note I repeated what you said?
  3. #3 Re: Making a relay harness for HID's (For Matt)
    Never Never Land
    So 86 would be the positive from the original harness right..since that would more or less be a "switch" telling the relay to turn on.
  4. #4 Re: Making a relay harness for HID's (For Matt)
    yes
  5. #5 Re: Making a relay harness for HID's (For Matt)
    Technically you shouldn't be putting the fused power source to 87 because then you are a bit backwards on the normal relay flow. Not that it'll have any effect on the relay...but it'll make you question why all other relays you look at are the opposite way.
    85 and 86 are a ground and power to trigger the relay. Typically the ground is the better one to toggle. That way if you route the trigger through the firewall and it gets grounded anywhere your item comes on adn you can trace down the grounding issue. I like to use a fused igntion on source for the other side. This means that even if your item comes on, it'll go off with the ignition. This may not be ideal for headlights though.
    30 is usually the power feed that you are relaying to the item you want to supply with power. (or ground if you are switching something)
    87 is usually fed from 30. The reason behind feeding 87 is that if you have a 5 pin relay 87A is fed in the non actuated relay position. So if you have two states you'd like to work with..you can. When the relay is at rest 30 and 87a are connected. When the relay is actuated 30 and 87 are connected. In a 4 pin relay, there is no 87A pin.
    I find that www.the12volt.com has tons of great info and explanations etc of how electronics work and why we'd want to use them.
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. HID Flickering with relay harness ?
    By jmalm321 in forum Visual/Body Modifications
    Last Post: 12-02-2010, 12:56 PM
  3. relay harness questions
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 02-27-2009, 04:14 PM
