Thanks for the help
1. Yes extra description would be great since I'm not sure if ill be able to fit 1/0 gauge wire under the plastic trim in the door sills.
2. I already have some 6 gauge wired into the car, but thats weak wire and i know it. I was busy the week i wanted to install it and since we get a pretty good discount on installs i figured id just let best buy do it since i didn't have the time. I had already bought the wiring kit original sub (an RE RExD4) upgraded to an RE SRxD4 and amp about 2 months prior. So i just let them use the kit i bought. Because thier the ones who wired it though im not sure if they did it the way your describing. So a better description would be great
3. As for the current box i built it myself, its a ported enclosure tuned to 35 hz that fires through the pass through door. I think it looks awesome plus i get a lot more notes with it facing forward and theres a really nice breeze on bass notes. However you get higher db's facing reverse which is why the next box will be dual SExD4's in a double enclosure with one sub and port facing into the cabin and a second in the back facing the trunk, ill scan the designs in later if you guys want to see it
4. I really dont like the idea of leaving the crossover blocks inside the doors since im afraid water might leak in a damage them. Especially since i know my trunk leaks through the spoiler bolts (im working on fixing this). So any other location ideas?
5. The wireing kit im using only gives me enough ground wire to ground the amps to the trunk. So should i just use the same place that best buy used in the trunk or is thier a specific place thats good
