Thread: HID + Projectors
Results 1 to 20 of 21
  1. #1 HID + Projectors
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    I am going to replace my headlights with HID and projectors and would like to have a little clarification. Judging by sight, it looks like the projector housings use two bulbs, one for hi and one for low. One looks projector and the other not. Which one is for low and which one is for hi? I assume HID's will work and they don't use 9007's for them both and the housing documentation will specify which ones. Please feel free to correct any misconceptions I have.
  2. #2 Re: HID + Projectors
    West Side Michigan
    Post a link to which Projectors you are getting. Then we can tell you which bulbs are for hi and low beam.
  3. #3 Re: HID + Projectors
    Lakeside Park, KY
    I haven't decided on a set of projectors yet. Just looking for general info.
  4. #4 Re: HID + Projectors
    West Side Michigan
    Well there are two styles you should consider, the two good projectors available for the GP that is..
    There are the spyder projectors which are the ones with two halos and the orange lights in the corner. Those take H1 bulbs for low beam and 9005 in the high beam.
    The other ones with the three LED's on the inner corner take H3 for low beam, and H1 for high beam.
    I have the ones with the three LED's. I like the light output, a lot better than the stock output. Spyders are supposed to have a crisper cut off line and a bit more out put. The ones I have put out plenty though.
  5. #5 Re: HID + Projectors
    Lakeside Park, KY
    So, do the lows go in the projector lens?
  6. #6 Re: HID + Projectors
    West Side Michigan
    Yes the low beams are what are in the Projector lens.
  7. #7 Re: HID + Projectors
    Lakeside Park, KY
    For a DD, is it worth getting HID's for the Hi's?
  8. #8 Re: HID + Projectors
    West Side Michigan
    Well when you flash HID's on and off and don't give them proper time to heat up, you shorten the life of the ballasts and bulbs. Plus I don't think any of the aftermarket projectors have good aiming for the high beams.. So No it's not worth it.
    You'll see plenty with just low beam HID's.
  9. #9 Re: HID + Projectors
    Ocala, FL
    I have hid's in my highs.. They work great.. Could never use them with traffic, I'd blind everyone.. And I never flash my highs, so it doesn't matter what people say about it being bad for them.
    Spyder auto projectors, by the way.
  10. #10 Re: HID + Projectors
    Lakeside Park, KY
    I guess the real question is, do I go with chrome or black? Both my GP SE's are the tan color.
  11. #11 Re: HID + Projectors
    Lakeside Park, KY
    Well, got my HID fog's installed. The difference is astounding!!!!! Now I can't wait to get my black Spyders in and get the matching headlights installed.
  12. #12 Re: HID + Projectors
    Norristown, PA
    Did you put hids in stock fogs?
  13. #13 Re: HID + Projectors
    Lakeside Park, KY
    Yes
  14. #14 Re: HID + Projectors
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    last I checked adding HID lights to a car that didnt come from the factory with them is illegal but maybe I didnt understand the rule correctly
  15. #15 Re: HID + Projectors
    West Side Michigan
    It is illegal. People still do it though..
  16. #16 Re: HID + Projectors
    Never Never Land
    ya its illegal...just aim them properly and you shouldn't have too much of a problem of blinding people. You don't have that problem much at all with projectors unless they're aimed terribly.
    I myself have the black spyder autos. Lo beams are great...hi beams IMO suck terribly....I'm ordering HID HI's tomorrow probably as well as a relay harness for the low and hi beams.
    The spyder auto lights are kind of hard to aim. It's annoying having to take the headlight off to aim, then reinstalling, remove, adjust etc. I would say it's worth it though with how much better the lighting is. Also don't over tighten the the 2 bolts that hold the light in, you'll break the plastic.
    They're also kind of hard to get flush with the fender. My driver side one is practically perfect. The passenger side one....it needs to come out easily 1/4 of an inch. I just need to adjust that all
    Overall the spyder lights are pretty good...i'd probably buy another set if I got another GP for some reason.
  17. #17 Re: HID + Projectors
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Like stated above they are illegal but I havn't heard of anyone that I know of getting pulled over for having them because I am not sure that cops know what cars came factory installed with them. From what I have gathered it is not illegal to have the HIDs if it came from the factory with those lights but it is illegal to install them as "aftermarket lights". I do know though that with the HIDs that I have in my car it makes my tint look way darker than what they really are (only got pulled over once)
  18. #18 Re: HID + Projectors
    GT Level Member jakewet28's Avatar
    Cincinnati
    Hey kinda thread jacking here... but do you need a harness for the fog hids like you do with the headlights?
    VS Cam, SS Intercooler, Powerflow catback, SSAC headers, open cone, 180* tstat, 42.5lb injectors, 2.8 pulley, 3.29 gears, zzp pcm, all supporting mods
  19. #19 Re: HID + Projectors
    Nov 2009
    If they are stock fogs then yes but if they are aftermarket you already have a wiring harness
  20. #20 Re: HID + Projectors
    Lakeside Park, KY
    I didn't get one. The flash bright and dim when I turn them on the brighten after a few seconds. I think the harness would take care of that behavior. I'll probably get one for my fogs when I do my headlights.
  1. zzp projectors
    By nascartech in forum Visual/Body Modifications
    Last Post: 08-04-2010, 12:42 AM
  2. Projectors
    By KSquared in forum Visual/Body Modifications
    Last Post: 06-14-2009, 02:47 PM
  3. New Projectors!
    By BoostenGTP in forum Visual/Body Modifications
    Last Post: 06-02-2009, 07:34 PM
  4. Projectors and HID's?
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-18-2009, 05:20 PM
  5. projectors....
    By 0LmtdGP3800 in forum Visual/Body Modifications
    Last Post: 05-16-2009, 10:47 AM
