From sounddeadenershowdown.com concerning Peel n seal/sound deadener/CLD tiles
CLD Tile is just a slightly catchy name for 6” X 10” pieces of constrained layer damper – what we’ve traditionally called sound deadener. If you’ve been doing any research, you have probably come across the usual arguments: “Buy the good stuff and cover everything” or “Buy the cheap stuff and cover everything with multiple layers.
The usual arguments miss the point. Products like this are vibration dampers. Their only purpose is to control resonance in a vehicle’s panels. Controlling resonance is the absolutely critical first step in any sound deadening project, but more isn’t better and trying to use a CLD to block sound is too expensive, too labor intensive and makes it unnecessarily difficult to do future vehicle maintenance. The old adage about using the right tool for the job has never been truer.
