Thread: Can you limit power draw through smaller wire? (no, bad idea for reference)
Results 1 to 20 of 27
  1. #1 Re: Can you limit power draw through smaller wire?
    GTP Level Member
    springfield IL
    Quote Originally Posted by 01gtp View Post
    all using smaller wire will do is increase the chances of the wire melting and starting the car on fire.
    +100000000000000004353556
  2. #2 Re: Can you limit power draw through smaller wire?
    Feb 2009
    Virginia
    Quote Originally Posted by tc300 View Post
    Not if you fuse it right. If it melts/catches fire you've done a few things wrong.
    11 is louder than 10!
  3. #3 Re: Can you limit power draw through smaller wire?
    Charles City, IA
    Quote Originally Posted by I800C0LLECT View Post
    If you have too high of an amperage fuse with the small wire it will melt. I am saying if you are using too small of wire in the first place you probably dont understand fuses or current draw.
    SMGPFC Two Nipple General
  4. #4 Re: Can you limit power draw through smaller wire?
    Feb 2009
    Virginia
    The key word is "FEW things wrong". My goal wasn't to dispute what you said...but if your wire is melting then you're using fuses inappropriately. I definitely agree with your second sentence! How about we use some links instead
    Recommended Power and Ground Cable Sizes
    Speaker Wire Calculator
    http://www.bcae1.com/images/swfs/spe...rassistant.swf
    "Low Power Blows Speaker"
    http://www.bcae1.com/2ltlpwr.htm
    Fuses
    FUSES
  1. Power wire amp to battery
    By yeacashgpgt2002 in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2010, 11:45 AM
  2. Amp power wire help!!!!!
    By Goldoni in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2010, 08:00 AM
  3. new power wire
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 12-23-2009, 03:35 AM
  4. Where to run power wire through firewall
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-05-2009, 11:59 PM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
