Thread: 3 subs on mono amp?
Results 1 to 18 of 18
  1. #1 3 subs on mono amp?
    IOWA
    okay so im running 2 12 inch alpine type E's and one polk audio dxi 4 ohm on a 1100 watt mono boss audio amp but when i turn up the volume to much the amp goes in protect mode is it cuz im overloading???
  2. #2 Re: 3 subs on mono amp?
    Jul 2008
    sumter,south carolina
    seems reasonable... is the gain turned up all the way?
    02 GTP with mods 05 GP for DD
  3. #3 Re: 3 subs on mono amp?
    IOWA
    about 3/4
  4. #4 Re: 3 subs on mono amp?
    Jul 2008
    what are the subs rated at?
  5. #5 Re: 3 subs on mono amp?
    IOWA
    Continuous Power Handling360W
    Peak Power handling720W is the Polk DXI
    type E's - 750W peak power (250W RMS)
  6. #6 Re: 3 subs on mono amp?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    ohm load for amp cuz if you have them wired like so:
    that could be the problem
    thats assuming they are all 4ohm SVC
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  7. #7 Re: 3 subs on mono amp?
    Feb 2009
    Virginia
    First and foremost...
    Gain: It is not a volume knob. Gain "matches" the input of the amp to the output of the head unit/stereo.
    Alright, now the issue. Most likely your amp is going into protect because it's clipping. A clipped signal is basically a sine wave. Not only that, but a speaker "load" actually changes based on temperature, frequency it's playing, etc. So your amp isn't "seeing" a 1ohm load. It's all over the place...
    In addition, you need to verify that all 3 subs have 4ohm coils. After you verify that your speakers are 4ohms a piece fix your gain. Clipped signals destroy pretty much everything in car audio. If you ever had a friend and their equipment failed...most likely it was from a "clipp'ed" signal. 90% of car audio failures are from clipping. Owners are just ignorant as to what happened and it's always "over powered" this or "under powered" that...Luckily you're a smart dude!! You have a an amp w/ protection mode
    Sorry if I came off as brash...I just like to be direct
    11 is louder than 10!
  8. #8 Re: 3 subs on mono amp?
    Feb 2009
    Virginia
  9. #9 Re: 3 subs on mono amp?
    Feb 2009
    Virginia
    Quote Originally Posted by TurboTrav View Post
  10. #10 Re: 3 subs on mono amp?
    Unless you have oldman's syndrome.
    "not loud enough, turn up the volume, just a little more.... a touch more..... *BOOM* damn...."
  11. #11 Re: 3 subs on mono amp?
    IOWA
    i have them running as positive to positive and negative to negitive and i twisted the three different postives together and same with negatives ? is that an ohm overload?
  12. #12 Re: 3 subs on mono amp?
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Quote Originally Posted by SIEBS View Post
    Yes, unless your amp is stable to run at 1ohm... Thats like what they pointed out, with them wired like that your at 1.34 ohms and most good amps are only rated to run 2ohms or higher. Cheaper amps are rated at 4ohms and will overheat and go into protect very easy when running anything less. So either turn the **** down, or buy a super amp that is 1ohm stable. Or wire them all into serries which will give you 12 ohms and put out very little power but your amp will be saved. 3 is a tricky number which is why its not a common setup...
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  13. #13 Re: 3 subs on mono amp?
    swift current,sask.
    Quote Originally Posted by Kejross View Post
    Look into an aq amp if you wanna keep running it like that then. I've had mine down to .7ohms with no problems at all.
  14. #14 Re: 3 subs on mono amp?
    Cedar Rapids, IA
    lol i have my 1200Ds strapped at 1ohm so each amp sees .5
    i've also had my old hifonics 1606D wired to .5 for daily then had a fellow bass head wire it to .33 burp and get 23xx watts out of it lol
    go class D regardless
  15. #15 Re: 3 subs on mono amp?
    Unless Im missing something here why 3 subs that dont match? and odd # subs always create ohm load problems unless you have a good amp that can handle the low ohm load why not just run 2 subs and each of them getting more power, a more stable ohm load, and turn the gain down. Again its not a volume knob like the others said. I highly suggest looking into learning how to "clamp" and amp thats the only correct way to run and amp.
  16. #16 Re: 3 subs on mono amp?
    IOWA
    okay what i did i found this wiring diagram and i wired them to a 2.7 ohm load and because i got 2 subs for christmas and i bought one at discount price at work
  17. #17 Re: 3 subs on mono amp?
    GTP Level Member
    springfield IL
    1 of 2 things.... you have something wired WRONG or the wiring is correct and the amp cant take the ohm load... ok 3 things.. LOL the type E's are 2ohm... cant mix and match subs(diff ohms)
  18. #18 Re: 3 subs on mono amp?
    GTP Level Member
    springfield IL
    there could be other stuff wrong also... gains and xover settings, start with the wiring first
  1. New Replacement Mono Leaf Spring
    By willwatsonfl in forum Brakes/Suspension/Chassis
    Last Post: 06-23-2010, 11:16 AM
  2. DD subs in a GP
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2009, 03:10 PM
  3. My new HID's and subs
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 06-27-2009, 09:55 PM
  4. mono amp vs two channel
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2009, 12:04 PM
