Thread: 3 subs on mono amp?
Results 1 to 18 of 18
  1. #1 Re: 3 subs on mono amp?
    GTP Level Member
    springfield IL
    Quote Originally Posted by SIEBS View Post
    okay so im running 2 12 inch alpine type E's and one polk audio dxi 4 ohm on a 1100 watt mono boss audio amp but when i turn up the volume to much the amp goes in protect mode is it cuz im overloading???
    1 of 2 things.... you have something wired WRONG or the wiring is correct and the amp cant take the ohm load... ok 3 things.. LOL the type E's are 2ohm... cant mix and match subs(diff ohms)
  2. #2 Re: 3 subs on mono amp?
    GTP Level Member
    springfield IL
    there could be other stuff wrong also... gains and xover settings, start with the wiring first
  1. New Replacement Mono Leaf Spring
    By willwatsonfl in forum Brakes/Suspension/Chassis
    Last Post: 06-23-2010, 11:16 AM
  2. DD subs in a GP
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2009, 03:10 PM
  3. My new HID's and subs
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 06-27-2009, 09:55 PM
  4. mono amp vs two channel
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2009, 12:04 PM
