Thread: swapped in Bose speakers... now only 1 works
Results 1 to 10 of 10
GtpKo swapped in Bose speakers...... 10-09-2010, 07:04 AM
ROTTMAN Re: swapped in Bose... 10-09-2010, 09:23 AM
GtpKo Re: swapped in Bose... 10-09-2010, 10:21 AM
Toofastgs Re: swapped in Bose... 10-09-2010, 10:43 AM
GtpKo Re: swapped in Bose... 10-09-2010, 07:39 PM
CTKGP09 Re: swapped in Bose... 10-09-2010, 10:33 PM
GtpKo Re: swapped in Bose... 10-10-2010, 10:23 AM
I800C0LLECT Re: swapped in Bose... 10-11-2010, 10:16 AM
GtpKo Re: swapped in Bose... 10-13-2010, 10:23 AM
I800C0LLECT Re: swapped in Bose... 10-13-2010, 05:52 PM
  1. #1 swapped in Bose speakers... now only 1 works
    GT Level Member GtpKo's Avatar
    Best place on Earth
    Earlier this week, I scored a couple bose speakers from an 00 GTP in the junkyard, the two front ones. First the front right one didn't work, maybe I didn't connect it all the way, OK, but then this morning the other front one(left) went silent as well as the rear left one? ? Great! Now I only have 1 speaker working. Rear speakers are stock as well as the cd player. Before I go tearing everything apart again, is it just a fuse somewhere? I'm no audio expert but swapping a speaker or two never hurt my other cars...
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  2. #2 Re: swapped in Bose speakers... now only 1 works
    Donating Users ROTTMAN's Avatar
    Feb 2009
    canada
    So you were trying to put 2 Bose speakers with a non bose system? You can't do that, they won't work. You need the entire Bose system, wiring, amp to make it work which in the end is not worth the trouble.
  3. #3 Re: swapped in Bose speakers... now only 1 works
    Best place on Earth
    u sure it won't work? as long as ur replacing a 4 ohm w/ another 4 ohm, should be fine. I had an old 1990 Olds Eighty-Eight that had super small "AM-radio quality" front speakers, replaced them w/ 2 from a 1990 GP, worked great! Is there something different electronically about bose speakers? All I wanted was to replace the blown stock ones.
  4. #4 Re: swapped in Bose speakers... now only 1 works
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    As far as i remember Bose speakers are 2ohm which is over driving the amp and is killing it.
    You cant replace 4ohm with 2 ohm unless the device powering it is rated for a lower ohm. But you can place larger ohm speakers in its place but your not getting all the power you would if you used the correct ohm.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  5. #5 Re: swapped in Bose speakers... now only 1 works
    Best place on Earth
    i suppose a 2-ohm resistor on each one would fix that. By the way I got these speakers for basically nothing and they're better than stock. I traced the problem to broken corroded wiring. That happens when wire is made on a Friday before a long weekend at the wire factory.. corrodes itself inside the insulator. I know if I wanted a boomin sound system, I would get the whole setup amps and all however in my opinion...here goes... subwoofers are a bit too "donk" for me.
  6. #6 Re: swapped in Bose speakers... now only 1 works
    Willoughby, Ohio
    you could get a litte 8 or 10 inch sub and stick it in the truck n push a few undred watts for nice sound without being donk
    imma bout to do this soon to save my door speakers since the front ones are crackeling
  7. #7 Re: swapped in Bose speakers... now only 1 works
    Best place on Earth
    I had a friend who put something like 2 14" w/ 600W twin amps in his old windowless chevy van. It was funny the looks we got in the "more urban part of the neighborhood". Personally I would love a full-range 5.1 system in my car. Maybe when I have a couple extra $1000 laying around...
    Last edited by GtpKo; 10-10-2010 at 10:23 AM. Reason: yes I know in Canada it's neighboUrhood
  8. #8 Re: swapped in Bose speakers... now only 1 works
    Feb 2009
    Virginia
    For $300....you could probably find a used amp and some nice speakers. But that's just for mids and tweets up front. I'm a fan of a/d/s/ Hell I even have 320is and 325is I'd let go for $75. Audio doesn't have to be expensive. People just presume it is.
    11 is louder than 10!
  9. #9 Re: swapped in Bose speakers... now only 1 works
    Best place on Earth
    I have scored pretty good at the local pawn shop in the past. When u see wires cut instead of disconn properly, it probably was "borrowed and sold w/o permission". But I guess thats how they can sellu a nice deck for $40. I'm gonna go back to that junkyard tho and pick up the rear bose speakers just so its all balanced, the front ones still sound much better even tho its not a full "bose" system
  10. #10 Re: swapped in Bose speakers... now only 1 works
    Feb 2009
    Virginia
    a/d/s/ 6.5", PX concept.2 T ads 346is 4ohm orion BEST! - eBay (item 380269570767 end time Oct-15-10 10:33:29 PDT)
    When first released...~$1200 or so. They eventually settled around a retail price of about ~$800 I believe.
    Either way, those are new. Not the same cross over, but really...active is much better in a car. Most guys I know just cut the wire. Too much work desoldering. Are they worth $250? That's arguable. It all comes down to paying for that piece of cake you enjoy. To some, price isn't an issue when indulging.
  1. Does Bose Work with Non-Bose cars?
    By grandprix17 in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2010, 08:07 AM
  2. 99 GTP A/C works great, then stops, then works great again
    By stotzbotz in forum General Tech Discussion
    Last Post: 09-27-2009, 02:39 PM
  3. stock bose speakers putting in a dvd deck
    By ssheibels8512 in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2009, 04:57 AM
  4. L67 Swapped
    By 99LuminaLSC in forum Chevrolet Lumina
    Last Post: 12-15-2007, 08:57 AM
