Thread: HID harness install ??
Results 1 to 20 of 20
  1. #1 HID harness install ??
    michigan
    i picked one up from W-body store but have no idea how to install it, here are the 3 ends, where do i hook them lol? i assume the red and black go to the battery, but i'm not sure about the blue one.
  2. #2 Re: HID harness install ??
    oh wow, that looks like the connector for your headlight bulb....
    lets see the entire harness though.
    They're all different and all screwy.
  3. #3 Re: HID harness install ??
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Well I know the red and the black go to the respected positive and negative terminals on your battery. Depends on the harness but the on the other ends, one should connect to the ballast and the other one should connect to the bulb, its that easy. If i remember it correctly...
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  4. #4 Re: HID harness install ??
    West Side Michigan
    Yessir.. red goes to battery, black is for ground. That blue one goes to where your stock headlight bulbs were. There should also be one more connector on the relay harness. This goes to the ballast, then the ballast connects to the HID bulb and you're set!!
  5. #5 Re: HID harness install ??
    michigan
    got it on, thanks guys.
  6. #6 Re: HID harness install ??
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    that one is differnt from my relay harness. I have like 5 ends to mine lol...and it looks like it's similiar to re-wiring the electrical lighting system. looking for a way to connect it to mine lol
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  7. #7 Re: HID harness install ??
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Quote Originally Posted by offroadfury6 View Post
    I have a feeling i know what urs looks like. post some pics up and i should be able to help
  8. #8 Re: HID harness install ??
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by csssaint12 View Post
    give me a few minutes...I'll take them now lol...I really wanna go full HID. Do you need a total of 3 harness for fogs, lows and highs?
    brb
  9. #9 Re: HID harness install ??
    Aug 2008
    Fayetteville, NC
  10. #10 Re: HID harness install ??
    Nov 2009
  11. #11 Re: HID harness install ??
    saskatchewan
    should of bought a cheap japanese set,i installed a set on a cavy tonight,just plug and play no wiring to the battery at all and they are super bright.the hardest part was deciding where to mount the ballasts.
  12. #12 Re: HID harness install ??
    Nov 2009
    Quote Originally Posted by savannaz34 View Post
    You still want to install a wire harness. Look at the specs for how many volts it takes to start the ballast up. It aint small so you want to go for wiring them up to a harness
  13. #13 Re: HID harness install ??
    Aug 2008
    Fayetteville, NC
    makes sense. so that fuse piece is just suppost to be plugged in? I thought it went to the fuse box or something.
  14. #14 Re: HID harness install ??
    Curly thing that glows.
  15. #15 Re: HID harness install ??
    Aug 2008
    Fayetteville, NC
    how the hell am I suppost to trim that? lol
  16. #16 Re: HID harness install ??
  17. #17 Re: HID harness install ??
    Aug 2008
    Fayetteville, NC
    csssaint...thanks for that diagram. I duno why I was dreading it. just wired up the harness and hide it well. It was toooooo easy. but without your diagram I would have ran that one end to the fuse box !
    Now I wait 'til dark to get you guys some pics. hopefully they are alot brighter and I wont have to do what Matt posted and modify my bulbs :\ I don't wanna go there.
  18. #18 Re: HID harness install ??
    Nov 2009
    no problem dude. always glad to help. let me know if for some reason that doesnt work. cant wait to see the pics
  19. #19 Re: HID harness install ??
    Aug 2008
    Fayetteville, NC
    looks better than this pic on the street. dunno why I couldn't get a good road pic.
  20. #20 Re: HID harness install ??
    Nov 2009
    Im glad that they worked for you.
  1. gt to gtp do they have same harness
    By smooth1lol in forum Off Topic Discussion
    Last Post: 05-01-2010, 11:50 AM
  2. Afc 2.0 ext harness
    By zexed99gt in forum PCM Tuning
    Last Post: 12-08-2008, 09:30 AM
  3. 04 GP GT Wire Harness.....
    By skubasteve! in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 03:41 PM
