Can't wait for the finished write up, maybe add pics/diagrams to it just to make everything simpler.
Also, the black plastic, couldn't you use what you cut out from the bottom of the cupholder?
Still working on the write-up, and you couldn't use what you cut out of the bottom because it won't cover the whole bottom of the acrylic. If you're ok with that then I guess you could try it out though lol.
And cerick08GP, I'll take some pics of me removing it for you when I take it out again to install the new and improved LEDs. For what it's worth, the clips are in the same spot you take the bolts out of, so pull on those areas (there are 2 in the front and 2 in the back). Also, you have to pull it out because there's a little notch in the front of it that hooks around some cylindrical knob.
Sweet, pics would rock. You may have given me enough info already for a third try. I know the exact knob you’re talking about, if it’s the one just under the dash area. Man I spent so much time looking at my center console it’s embarrassing.
FYI when I go back in, I plan on adding a 12V socket. On my car neither one is in a good spot for my GPS so I’m going to add one on the passenger side of the console. I haven’t noticed any one talk about that here so I just thought I’d throw that out for an idea.
